Old 10-20-2018, 09:52 AM   #15
beetlegreg
Drives: Turbo beetle
Basic-there are 2 paths for pcv 1 when under vac condition you are using the intake path, 2 when under boost you are using the rear pcv as turbo spools it creats a suction on rear hose. there is a couple of checks in the pcv unit when they go bad or leak they allow boost pressure to flow from intake to crankcase. can you say rear main leak.
you can install an extra check valve external in intake pipe. Also know that when the temp drops from summer to colder conditions there is a lot of condensation-water vapor collected in the can especially during stop and go driving
beetlegreg is offline   Reply With Quote
Old 10-20-2018, 11:56 AM   #16
kglewis1
Drives: MK6 GTI '11
Originally Posted by Turbo Beetle View Post
Most of the time I empty my can every 7-10 days and there is aprox 1-2 inches of a mixture of water and oil
( mostly water)
You can start your car without the MAF sensor plugged in (and drive if you want) and if the idle surge goes away you may want to clean or replace your MAF. If you unplug the MAF and start or drive the car you will want to clear any error from the unplugged MAF.
I'll try unplugging my MAF today. I did already pull and clean it, however it very well could be on its way out.
7-10 days still seems excessive, but I'm no expert. Consider this... With the intake hose in place, I haven't collected an inch of fluid in a couple thousand miles, but the catch can is still functioning under boost when it is suppose to be needed the most. Maybe someone with a catch can other than the ECS system can chime in, but when I was looking into the apr setup I believe it said you needed to drain the can yearly. I don't understand where this huge difference in fluid collection is coming from. In my experience with my can, most of it is water but there was also enough oil in there too notice a drop in oil level over a longer period of time.
Edit: I disconnected my MAF and my car was ok for a couple hours before it began idle surging again.
kglewis1 is offline   Reply With Quote
Old 10-21-2018, 08:49 PM   #17
zef
Mine fills up in a single 30 min session on the track
Just did a track day today with the ecs tuning catch can with the front pcv hose attached. Cleaned out the catch can right before I left for the event. After coming home and checking it it's literally bone dry just how I left it after I cleaned it in the morning.
Wondering if all that oil just dumped into my intake manifold (but then again I didn't have blue smoke) or the front pcv pulling vacuum somehow keeps the oil from spilling out (or could just be the drop in crank case pressure)
Old 10-21-2018, 10:16 PM   #18
mraaf
Drives: 2011 MK6 GTI
Exactly this.
The ECS only catches oil by help of rear vacuum from turbo inlet (during boost mode) while eliminates front vacuum from intake manifold during N/A mode (idle).
REVO 3
mraaf is offline   Reply With Quote
Old 10-22-2018, 12:10 AM   #19
kglewis1
Drives: MK6 GTI '11
Originally Posted by mraaf View Post
Exactly this.
So if this is true, and the ECS can is catching oil in boost, why does reconnecting the intake to the PCV, which only changes operation at idle, so greatly reduce fluid being caught in the can? I don't seem to be catching anything anymore, yet my can is still 100% operational under boost.
Old 10-22-2018, 02:54 AM   #20
mraaf
Perhaps it has nothing to do with re-connecting front vacuum. It is more to your driving condition. I haven't catch anything while daily driving but would catch about 200-300ml of pure engine oil when hitting 4 hours session track days. If I were catching oil during daily drive, I would be worry about excessive blowby.
I have same setup as ECS but with front PCV connected.
Refer to page 14 for PCV operations: http://www.vaglinks.com/vaglinks_com...fsi_engine.pdf
REVO 3
Old 10-22-2018, 09:03 AM   #21
Tony48
Tony48's Avatar
Drives: 2011 GTI / K04 / 6MT
Thanks for the link. Good read and saved for future use. Diagrams from that document of pertinence to the conversation here:
2.0TSI PCV Valve Unit by Tony G, on Flickr
2.0TSI PCV Overview by Tony G, on Flickr
Old 10-22-2018, 10:39 AM   #22
zef
I just did a track day yesterday and my catch can was spotless after. I'd typically have to empty it as soon as I get home (or during the event depending) if I left that front hose blocked off.
Blocking off the front hose must increase the suction of the rear pcv which causes the can to fill so quickly.
Old 10-22-2018, 11:22 AM   #23
mraaf
My other concern on PCV gas which is re-route back into engine is heat its carries, which I think might reduce efficiency of the intercooler. Thinking of having a small gas cooler (with a drain valve) after the catch can.
REVO 3
Old 10-22-2018, 01:15 PM   #24
kglewis1
Drives: MK6 GTI '11
I believe it actually causes positive pressure in the crankcase during N/A or idle which is causing oil/fluid to be pushed into the can. This is my experience anyway. With the ports blocked off, I had pressure under my oil cap which caused oil splatter to blow out if the cap was removed. My understanding is that this is normal for this setup.
My concern here is how much of this blowby is getting pasted the can? Yes it goes into the turbo, but if this is happening during idle what's the effect going to be? Dirty IC?
I just bought a replacement maf, map, and iat. Having just installed the iat, I don't believe this is causing my surging issues. Next will be the map, and last the maf. When I get to the maf, I'm going to cut my injen intake into two, and insert the stock MAF housing as I've seen reports that this intake may cause lean issues.
Edit: Swapped MAP and no improvement.
Edit 10/26/18: I cut my intake up and reinstalled the stock MAF housing. Not only has this fixed the issue, but the sensor is now facing up for easy access in the future.
Old 10-22-2018, 10:00 PM   #25
mraaf
*Oil loss due to idle blowby (daily/city drive) = Engine oil volume day 1 - engine oil volume day 30 - oil volume in catch can day 30
* assuming ECS setup with front hose connected
REVO 3
