Old 10-20-2018, 11:05 AM   #1
GeorgiaBII
GeorgiaBII's Avatar
Drives: 2011 APR Stage 2 DSG Autobahn
Where to buy timing chain components?
I've got a new to me 2011 GTI autobahn with 112k on the clock. Far as I can tell it's not had a timing chain and I do NOT want to risk failure.
So that said I'm going to replace the chain and all associated bits. Is ECS the place to buy the parts or is there a better/cheaper supplier of OEM updated parts?
Right now I'm looking at:
https://www.ecstuning.com/b-genuine-...kit/06h198004/
Plus a lower cover.
GeorgiaBII is offline   Reply With Quote
Old 10-20-2018, 11:47 AM   #2
tehred5pade
Drives: cc
I like shopdap. They have reward points and by the time I bought my kit, I had enough points to pay for a new dsg filter I cracked when reinstalling my transmission
Mods- high flow drop in air filter for the 15hp the box says
tehred5pade is offline   Reply With Quote
Old 10-20-2018, 11:55 AM   #3
tehred5pade
Drives: cc
https://www.shopdap.com/make-model-y...pdate-kit.html
This is all you need imho. Your oil pump chain is fine and doesn't need timing. The balancer shafts are prolly fine too. You might want new engine mount bolts as those are stretch bolts but that's up to you. Also the kit you linked has a balancer shaft tensioner... I wouldn't worry about that either
You'll need some special tools too but that's about it. Shopdap has a cheap crack hold tool is the only specialty too you'll need imo. The sprocket holder tool (the plastic spacer) isn't needed. Use a nut larger than the crank bolt and you've saved yourself money.
Good luck
Old 10-20-2018, 12:32 PM   #4
Blakcard
Blakcard's Avatar
Wow... thanks for the link
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old 10-20-2018, 04:34 PM   #5
smanierre
smanierre's Avatar
FCPEuro has a lifetime warranty on all their parts, even the wear and tear ones. If you plan on keeping the car long enough where you'll need to do this again then you can just send the old parts back and get the new ones fully refunded
Old 10-20-2018, 11:29 PM   #6
Blakcard
Blakcard's Avatar
And looks like it's the new style gain too..
So... I can return parts for wear and tear? Wow... solid deal
Old 10-21-2018, 01:28 AM   #7
BudgetPhoenix
Drives: 09 GLI
I was able to find OEM parts on ebay cheaper than most other places. Make sure its legit and not one of the chinese pieces listed as OEM. Lots of VW dealers selling stuff on ebay. I pieced together my own kit. I used a variety of sources though. It helps to go to google shopping search the piece you need by part number then sort it low to high.
Old 10-23-2018, 12:43 AM   #8
Turbo Beetle
Drives: 2012 Turbo Beetle
What was the total for the kit you put together.
Turbo Beetle is offline   Reply With Quote
Old 10-24-2018, 10:47 AM   #9
mapatni
If you're looking for a full kit for MK6 2.0 TSI I've assembled one. I purchased it prior to learning about the extension of warranty to 10 yrs/ 100K miles. I figure there is no point in storing these parts in the closet until I hit end of warranty so I'm trying to sell them. I've included a serpentine belt because I figure it's a good idea to replace while I'm in there....and the lower timing chain cover for production dates PRIOR to 12/12/2011. If you don't want the cover but want the rest I'm willing to exclude it. All parts are Genuine VW OEM:
With cover total kit price is: $640
Without cover kit price is: $440
I'll include shipping. Let me know if interested.
Here is a line item list of all the parts included +/- the lower timing chain cover depending on if you want it or not.
Updated Timing Chain Tensioner 06K109467K (VW)
Crankshaft Pulley Bolt WHT001760 (VW)
Engine Mount Bolts N10552402 (2), N91029602, N90596906, N91167101 (VW)
Engine Mount Bracket Bolts x qty 3 - N10701501 (VW)
Lower cover bolts x qty 15 - N91096702 (VW)
Upper Timing Chain 06K109158AD (VW)
Timing Chain Tensioner Lower 06H109467AE (VW)
Torx Bolt x2 (lower timing chain tensioner) N10554005 (VW)
Timing Chain guide rail lower 06H109469AH (VW)
Timing Chain guide rail lower 06H109469AQ (VW)
Timing chain guide rail lower 06H109509P (VW)
Timing chain guide rail Upper 06H109469AP (VW)
Timing Chain guide rail upper 06H109469T (VW)
Timing Chain Guide Rail Upper 06H109509Q (VW)
Torx Screw x2 N91130301 (Left Timing Rails) (VW)
Torx Screw x6 N91130401 (Right Timing Rails) (VW)
Timing Cover Sealant D176404A2 (VW)
Camshaft Adjuster Magnet Gasket 06H103483D (VW)
Upper Cover Gasket 06H103483C (VW)
Front Crankshaft Seal inside cover plate 06L103085B (VW)
Optional Timing chain cover lower (production date up to 12/12/2011) 06H109210AG (VW)
Serpentine Belt 06J-260-849-D (VW)
mapatni is offline   Reply With Quote
Old 10-24-2018, 11:01 AM   #10
CHerna
CHerna's Avatar
x2 for FCP Euro
Challenger Scat Pack Widebody
