Old 06-26-2018, 06:06 AM   #1807
Stock-GTI
Stock-GTI's Avatar
Drives: 2013 MK6 GTI
Originally Posted by davisharr View Post
Trying to do my log today for the MAF cal, but I cant for the life of my find any "Accelerator Pedal Position" option in my logging parameters, have scrolled through multiple times now, that parameter doesn't exist in my car for some reason. Have looked for alternatives too like Throttle position and stuff but nothing that sounds right. Perhaps something to do with being a DSG not manual? Anyone else have this, can I still send my logs away without it? Figure I would ask here before contacting Stratified as they are often swamped and I wana get this log done on my day off later in the week!
Should be labeled APP on the List.
13 MK6 GTI CW DSG | Stratified | Integrated Engineering | Cobb | Turbosmart | ARM | Forge | GruvenParts | Fluidampr | Neuspeed | TyrolSport | ECS Tuning |
Old 06-26-2018, 02:09 PM   #1808
ce4
Drives: 2013 VW GTI CSG DSG
Just recently changed over to the Stage 1 93 tune I got from Stratified. Butt dyno is registering moar power...however i've noticed there is a bit more lag than the 91. No CELs. Should this be expected or is there anything I should be checking on?
Cobb AP/AF | Stratified Stg 1 91//93 tunes | Powerflex LCA Bushings | GFB DV+ | DeAuto LEDs | RoxBloxz Mud Flaps | Continental DWS06 | DYC Brass Monkey | Beluga Racing CBE
Coming Soon 3" Catless Downpipe, Intake of sorts and Stage 2 Tune
ce4 is offline   Reply With Quote
Old 06-26-2018, 02:15 PM   #1809
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Depends, they max have used more timing and less boost sp you making power but doesnt feel like its boosting you in the seat. Just check logs and compare. Check load actual and see if the car is making more load.
Sent from my SM-G960U using Tapatalk
Old 06-26-2018, 05:03 PM   #1810
thatspsychotic
thatspsychotic's Avatar
The 93 octane tune may give higher peak torque a little later in the RPM band, which makes it "feel laggier." Or, if they used a little more boost in the 93 octane tune, it should feel like it takes longer to get to the peak torque, because it does take longer to get there, because you have to create more boost, which takes more time.
APR Stage 2 v2.4, Carbonio, Cast Downpipe | PTP Turbo Blanket | GFB DV+ | Unibrace UB | Tyrolsport Deadset | BFI Stage 1 Mounts | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18
Old 06-27-2018, 12:02 AM   #1811
davisharr
davisharr's Avatar
Drives: 2012 Mk6 GTI
Thank you that was it! Logs sent!
2012 GTI
1991 Mazda Miata
davisharr is offline   Reply With Quote
Old 06-27-2018, 12:39 AM   #1812
RaySkodaTSI
Drives: Skoda Octavia 1.8TSI 6MT (Mk2) K04
Anything for a 1.8TSI Gen 2 with K04?
RaySkodaTSI is offline   Reply With Quote
Old 06-27-2018, 07:04 AM   #1813
CHerna
CHerna's Avatar
Drives: S.S. Challenger Scat Pack Widebody
I don't think Cobb makes an Accessport for that model. Stratified tunes through the Cobb AP.
Old 06-27-2018, 12:54 PM   #1814
ce4
Awesome!! I'll check logs and see if anything stands out.
More torque = moar time...makes sense
Old 06-29-2018, 03:13 PM   #1815
fuelforfire87
Drives: 2013 Volkswagen GTI APR K04
I currently am APR K04 with APR's tune. If I switch to a stratified tune, do i need to have my ECU flashed back to stock?
2013 Red MK6 DSG. APR K04 v3.2. APR DSG tune, Cobb turboback exhaust. Eurojet Intercooler, AWE TOP, ECS TB Pipe, ECS Spherical Dogbone mount and Spulen insert(street). ECS Motor and Tranny mounts. MFactory LSD, ECS Catch Can, Neuspeed RSe12 Wheels, Continental ExtremeContact Sport 235/40R18 Tires.
fuelforfire87 is offline   Reply With Quote
Old 06-29-2018, 03:19 PM   #1816
smanierre
smanierre's Avatar
Nope, once you install the accessport and flash the tune it will overwrite the APR tune
Old 06-29-2018, 04:47 PM   #1817
fuelforfire87
So once I overwrite the APR tune there would be no going back other than going to an APR dealer and having them reflash the ECU?
Old 06-29-2018, 04:52 PM   #1818
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
Correct
Old 06-29-2018, 05:39 PM   #1819
smanierre
smanierre's Avatar
Originally Posted by sterkrazzy View Post
Correct
What if he is the original purchaser and has proof? Not sure but you could try and say something along the lines of the dealer put it back to stock somehow
Old 06-29-2018, 05:41 PM   #1820
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
You still own a license to the apr software for your car so all you have to do is pay the tuners labor fee which is usually only about $50. You don't have to buy the tune again, but you do have to go back and have it flashed again.
