Old 12-24-2015, 10:58 AM   #1
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
Fuel filter lines crack after install?
I swapped fuel filter a couple hundred miles ago, today I went to start and got an unlimited crank, checked the street and I smelled that sweet 91 octane. I checked the filter and the bottom connection was off. It doesn't snap back on and it looks like a small crack inside the connector. I am 99.9% sure I didn't break it but all in all its fucked, I electrical tapped it to the filter and to the other line. I'm on the road but is there a way to re connect them after taking them off? They should just snap back on and that's it right? Also how hard to drop the tank and swap that line?
MK6 GTi PZEV United Gray | Kohlefaser Luft Technik Intake
Old 12-24-2015, 11:29 AM   #2
notovicrious
It keeps popping off even with electrical tape even though the clip is still attached, inside the connector under the clip is cracked, I put a small bungee on the connector and pulled it to a hole in the shield piece. Heading to Advanced auto parts to grab a line repair kit, trying to avoid dropping the tank.
Old 12-25-2015, 05:41 PM   #3
notovicrious
Bump, does the auto parts store repair kit method work? Should I replace the whole line?
Old 12-25-2015, 07:49 PM   #4
GeorgiaBII
FIA GT Champion
GeorgiaBII's Avatar
Drives: SOLD!
Yes the repair kits work just fine. You'll need to heat up the plastic line a bit with a hair dryer to make the fix but it's an easy one.
I've done this several times over the years with great results.
Mods:42DD Down Pipe/Nav 315/APR STAGE 2/Stevens 620a /New South Boost Gauge
GeorgiaBII is offline   Reply With Quote
Old 12-25-2015, 07:53 PM   #5
notovicrious
Thanks a lot for the confidence booster. Did you get a 5/16 connector and a 5/16 line? I have one but I think the line is 3/8?
Old 12-25-2015, 08:35 PM   #6
GeorgiaBII
FIA GT Champion
GeorgiaBII's Avatar
Drives: SOLD!
No idea on the GTI. I've done these repairs on fords, chevy's, and dodge.
Old 12-26-2015, 02:15 PM   #7
notovicrious
I used a 5/16" ford repair kit (quick disconnect) 90* angle. It worked great. Bought a heat gun and the kit for 50 bucks. Lifted the rear seat, unhooked the line from the pump and tied a rope to it. Cut off the bad connector which in the end was never cracked, just stuck in which allowed the connector to push off every time I opened the door and spliced the repair kit on to the old line. No stealership no hassle no problem. Thanks for the help.
