Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > Southeast
Old 08-29-2015, 10:37 AM   #71
BensWhtgti
BensWhtgti's Avatar
Drives: Volkswagan Gti
Does anyone know want i need so that my battery wont when having a sound system
Sent from my SM-G920V using Tapatalk
BensWhtgti is offline   Reply With Quote
Old 08-29-2015, 10:41 AM   #72
A second battery on a solenoid or a remote starter with voltage detection.
Old 08-29-2015, 06:06 PM   #73
ManofVoice
ManofVoice's Avatar
Drives: 2010 GTI Autobahn
Originally Posted by bwillet View Post
Ok, so far, this thing is pretty bad ass! It's basically an Android tablet in the dash that plugs into the car's existing wiring. Very fast and responsive, screen is pretty nice. 1024x600 resolution. It actually includes Torque and a few other apps already.
This is just a quick off-the-cuff list of pros and cons, I'm sure there are more of both....
Pros:
- Fast
- Sounds good
- Super easy installation
- Waze, audiobooks, etc. all work great
- Lots of hacking support on xda-developers (rooted the thing in about 5 seconds). Soon I will make a bunch of tweaks like hiding the title bar, adding swipe controls, etc.
- Home screens are very customizable even without hacking. Whatever apps you load you can decide whether to put them on the home screen or not. It's basically just like radio presets.
- Default apps are easily changeable. I was able to easily select Waze as my default navigation app, but I also have CoPilot installed for no-data backup. I'm going to load Here maps as well, but haven't played with that yet.
- Two microSD card slots, both accessible through Android.
- The DVR functionality (dash cam, just add $20 usb camera) can write to the GPS card, normal SD card, or USB flash drive.
- The only "Engrish" I have found on the unit itself is buried down in the factory settings menus, that you have to type the double-secret password to get into. Otherwise it is a nice and polished unit, looks very good and not too cheap.
- Not that I plan on it, but it's just a matter of clicking a checkbox to bypass the whole "can't play video while driving" thing and stuff like that.
Cons:
- Boot time is a little slow. Not as slow as the Eonon I had before, and not that much longer than the stock head unit, but noticeable. Haven't timed it, but maybe 20-30 seconds. Just long enough to be annoying. If you are the type that starts the car then immediately starts to drive, it would be annoying. if you start the car and let the oil start circulating, put on sunglasses, buckle up, etc., it's fine.
- When playing music through bluetooth, controls work fine, but you don't have any artist info, etc on the screen. Normally that would bother me, but since I'm going to be using Google Play Music, audiobooks, and music from SD on the head unit itself, and not through bluetooth, it is really a moot point.
- I would rather have volume knobs than buttons, but I usually use my steering wheel controls anyway, so I guess that's fine.
- Bluetooth has not automatically connected 1 time out of the last 10 or so. Just had to click the button to connect, but no idea if that will be an issue or not.
- I am going to have to do the slightest bit of sanding around the edges of my trim bezel, as the head unit is probably half a micron too big. I can force the bezel on there, and it will kind of stay, but you can tell (if you are looking for it) that it is stressed. We are literally talking 2 or 3 swipes around the inside of the bezel with fine sandpaper. Won't affect the fit of the stock unit at all either, so not too big of a deal, just annoying.
- The built in mic SUCKS. Definitely have to use the external mic, no question. I will hook that dude up when my cameras arrive hopefully next week.
I'm too impatient for pictures right now. Got other stuff to do. Pictures and more info later, after I've had more time to play with it.
So far, overall, I'm loving it. I did NOT have the same feelings after a few days with the Eonon unit I had last year...
Thanks for sharing. Looking forward to seeing the pictures. I like the fact that it fits like stock. Still waiting for the perfect CarPlay/ANDROID AUTO unit (that's if it is ever built). Must have as quick as stock boot and as quick as stock BT connecting. T
2010 Black 4DR Autobahn DSG|aSPEC Charge Pipe| aSPEC Turbo Outlet Pipe |LED Interior Light Kit|Unitronic Stage 2 ECU|DG Springs|Luft-Technik Intake|R8 Coil Packs+NGK plugs|GFB DV+|Godspeed Downpipe|Magnaflow Hi-flo Cat
ManofVoice is offline   Reply With Quote
Old 08-29-2015, 06:11 PM   #74
ManofVoice
ManofVoice's Avatar
Have you had battery issues with your current setup? I've been running a modest amp to a 10" woofer since I got the car and haven't had any issues. I could grab the specs from my battery if you want.
Old 08-30-2015, 05:29 PM   #75
BensWhtgti
BensWhtgti's Avatar
Yea it seems to me that after a few hours of not running my car it drains the battery n i only know that becuz ive left it without the amp on.
N yes plz thanks
Old 09-02-2015, 09:44 PM   #76
ericwood311
Drives: 2015 Deep Pearl Black GTI S w/PP
Hey Atlanta Crew... I know it's been a while since I've made it to a meet.
Anyways, I've upgraded to a MK7 GTI w/ Performance Pkg and I'm now selling my Koni Yellows and Neuspeed Race Springs. Posted in Classifieds here: http://www.golfmk6.com/forums/showthread.php?t=95165
I'm going to try to make it out to the next meet though, if MK7's are welcome...
ericwood311 is offline   Reply With Quote
Old 09-03-2015, 10:42 PM   #77
BensWhtgti
BensWhtgti's Avatar
Hey guys anyone where to get H15 in colors
Old 09-04-2015, 05:14 AM   #78
ShrekSquatch
ShrekSquatch's Avatar
Drives: 2016 Oryx White Golf R DSG w/DAP
I saw your for sale threads, wondered what you ended up getting... Definitely, come on out!
Sep 12, right peeps?
2016 Oryx White Golf R with DSG, DCC, DAP, and some DIY. Tint, euro tails, hardwired dash cam, JB1, euro folding mirrors, S3 resonator delete, PedalBox
ShrekSquatch is offline   Reply With Quote
Old 09-04-2015, 12:56 PM   #79
Dante_Rez
Drives: 2014 Wolfsburg GTI DSG
Anyone doing rear wiper delete, go with Urotuning plug not ECS. Uro is half the price and better/easier to install.
2014 GTI 4-door, DSG, Carbon Steel Gray Metallic
ESC Smoked Side Markers| PIAA Yellow Fogs | Sylvania zXe bulbs | Amber Parking & Int bulbs | Euro cupholder | Tinted
Planned: APR Stage 1 & Carbonio Intake | Stoptech Street Pads & SS Lines | Tyrol Stiffening Kit & Masterbracket | UB | Rear Sway |
Dante_Rez is offline   Reply With Quote
Old 09-04-2015, 04:45 PM   #80
Dante_Rez
I'm good with the 12th
Old 09-04-2015, 09:19 PM   #81
ManofVoice
ManofVoice's Avatar
N yes plz thanks
Here's what I've got powering my sound...
Amp: Power Acoustik LT-480-2 (250/450 rms/peak)
Sub: Pioneer TS-SW2502S4 (@4ohm)
Battery: Autocraft Gold 47H5
Cold Cranking Amps: 650@0F/810@32F
Reserve Capacity: 100 (probably the number you want to look at on yours)
Posted from iPhone 6 Plus using Tapatalk
Old 09-04-2015, 09:20 PM   #82
ManofVoice
ManofVoice's Avatar
Sept 12...
YUP!
Old 09-04-2015, 11:27 PM   #83
rkellis
rkellis's Avatar
Drives: 2012 GTI 4DR DSG
I'm in for the 12th.
2012 GTI Autobahn 4-Dr DSG - Deep Black Metallic
APR Stage 2 / APR Stage 1 Intake / APR DP / P3 Gauge / Depo LED Tails / LED Turn Signals / Euro mirrors / Climatic / NUESpeed RS with Endlinks / VW Swag / Smoked side markers (Sylvania 2827 LL amber bulb) / UNIBrace UB / DeAuto Interior LED Kit / 35% Tint / ECS Hatch Pop Kit / Misc VAG Tweaks
rkellis is offline   Reply With Quote
Old 09-06-2015, 08:31 AM   #84
BensWhtgti
BensWhtgti's Avatar
I appreciate it thanks
