2.3b stg2 is so great
Still shifts like shit on my car. IMO worse shifting compared to 2.2b
That sucks to hear but i thoroughly believe you. If it was so great I think they would have released it to everyone. I have gone back stock, and honestly i'm loving it. The smooth shifts, and seemingly better low end power is more fun and usable on the street.
With the tune, the real power seemed higher in the RPM range and there's hardly a chance to really use it. I liked the old file better.
I'm a manual as well and I'd like to get 2.3, but it looks like that isn't even possible anymore.
I've been flashed with every version of v2.x except v2.4.
I don't understand why their calibrator cannot figure out how to get a dsg car to shift right. I have begun to look into other tunes but I'm apprehensive to take a loss in power. Or I may just do a k04.
If everything else about 2.3 was nice except DSG shifts, then it's probably pretty great for manuals. I somehow doubt it will see a final release though.
Driveablity is what it's really about for me.
Anyone else notice issues with the normal (high) output's torque?
Can you be more specific than "issues"? I have some issues with high output file on V2.1, mostly very abrupt use of the diverter valve for boost overshoot control. Results in very jerky hesitations when rolling into boost, and unnerving wavering of the boost gauge needle. I also spiked to almost 23 psi once today and got a VERY sharp and abrupt boost dump via DV, almost like a protective boost cut. Hadn't had that before though. Cooler temps maybe?
Seems like they're really hanging out on the ragged edge of the IHI turbo here. Could also be my setup, maybe the DV action is exaggerated due to the extra mass of the DV+ piston compared to the rev D DV.
The extra power causing the DSG to act odd. My DMF (taking out clutch pack) went a week after going to the higher output tune. I blame that on VW's shit build quality and warranty (09 cars got a 100K DSG warranty).
Replaced DMFs/clutch pack. My car shifted poorly even in low output (jerky pulling away and slowing down) but the higher output tunes resulted in rough engagement of lower gears on downshifts.
By rough I mean hearing a gear grind going into 2nd. Did a 2nd DSG flush (there were some metal shavings in the oil my mechanic saw after I got my car flushed during the repair) and replaced the K1/K2 & pressure solenoids. The car shifts great in low output.
High output still results in some shifting problems. They show their head shortly after.
What should we expect though? It's 35 ft/lb more than the original stage 1 tune. Some Mk7 Golf R tunes have less torque than the 93 high we get.
whats the tune youre referring to?
