Old 12-10-2010, 07:50 AM   #1
DJEuphoria
DJEuphoria's Avatar
Drives: 2011 6-Spd Black GTI 2-Door
The FK Coilover Thread.
there's so many variations of Fk's on the market ranging from $500-$1200...
i'm definitely going with FK Coilovers within the next 2 months and i'm having trouble deciding which ones to get. i just wanted to hear what you guys have to say about them. so if you've got pics, issues, or praise for the FK's spill em here and let us know!
talk about:
FK Streetlines
FK Highsports
FK Konigsports
FK Silverlines
FK Silverline-X
i'm looking to go <23" FTG on 18's while maintaining a decently comfortable ride. Performance isn't that important to me.
i was just wondering if it made sense to get $900 Silverlines when i can get $550 Streetlines...
DJEuphoria is offline   Reply With Quote
Old 12-10-2010, 09:45 AM   #2
DRedman45
DRedman45's Avatar
Drives: UG '10 4dr gti(sold)-E86 //M coupe
Send a message via AIM to DRedman45
seeing how you are in jersey it is definitely worth it...plus you should remove the helper springs in the front they make those coils noisy as anything
the only other coil that will go as low as silverline-x's is probably ksports
forgot to say the salty air in jersey will seize up the coils more easily than in other areas
DRedman45 is offline   Reply With Quote
Old 12-10-2010, 09:52 AM   #3
Jerz
Jerz's Avatar
Drives: MK6 GTI
I have Highsports and love them.
Jerz is offline   Reply With Quote
Old 12-10-2010, 11:57 AM   #4
absoluteczech
absoluteczech's Avatar
Drives: 2016 GTI 4DR CSG
you cant. those 2 things just simply dont go together.
gotta pick one. comfortable ride, or slammed
absoluteczech is offline   Reply With Quote
Old 12-10-2010, 01:07 PM   #5
Jerz
Jerz's Avatar
Drives: MK6 GTI
Yep, my ride is really bouncey and rough at times. You get used to it though.
Old 12-13-2010, 01:05 PM   #6
1FlyGTI
1FlyGTI's Avatar
Drives: 2011 MK6 GTI
hey guys since alot of people say racelands are crap, I am thinking about getting myself FK Konigsport coilovers. I got a couple of questions for ya . What does dampening adjustment exactly mean? How do you adjust them? Last but no least it says on the website that the rear can be adjusted when dissembled, what in gods name does that mean? thanks in advance heres the link to the site http://www.esetuning.com/FK-Automoti.../fkkkvw102.htm
2011 UG GTI | Bagriders | Airlift | GintyFab | Instagram @mk6mike25
3SDMs ARE FOR SALE!
1FlyGTI is offline   Reply With Quote
Old 12-13-2010, 01:12 PM   #7
DRedman45
DRedman45's Avatar
dampening is basically haw stiff you want the shocks to be...the fronts all you do is turn a knob the rear you have to take off the shock then adjust it
Old 12-13-2010, 03:27 PM   #8
DJEuphoria
DJEuphoria's Avatar
so basically, i probably shouldn't get anything under the highsports, right?
i guess at that point i'll just spring for silverlines.
Old 12-13-2010, 03:32 PM   #9
DJEuphoria
DJEuphoria's Avatar
also, did any of you guys replace your Strut Bearings?
Old 12-13-2010, 03:43 PM   #10
euro89
euro89's Avatar
Drives: CW MK6 GTI, Manual
i still cant figure out which go lower without taking shit out.. fks or ultra lows
*** M Y - P R O J E C T***
euro89 is offline   Reply With Quote
Old 12-13-2010, 03:50 PM   #11
RSMark5
RSMark5's Avatar
Drives: 3.6 4mo, 9k Aero
Both of them go low enough you really don't need to worry about which go lower. If say Ultra lows went 1/4" shorter, that means you'd be about 1/4" subframe to ground. Fk's easily take you < 22" FTG.
Also, Id stil get streetlines. Just use that silicone grease people use. 1 can of that every year is way less than paying double for the same coils. I forget exactly what the product is called, maybe some one else can fill you in. It keeps things from rusting in winter.
Also, definetly just replace the mount/bearing, especially if your having some one else install the coils for you. You won't want to pay some one to uninstall them, replace bearing, then reinstall.
RSMark5 is offline   Reply With Quote
Old 12-13-2010, 03:54 PM   #12
DJEuphoria
DJEuphoria's Avatar
THANK YOU!!!
that exactly what i needed to hear. i posted this thread on MK5 forums on Vortex and couldn't get solid answer.
Old 12-13-2010, 10:13 PM   #13
rizzogti
rizzogti's Avatar
Drives: 2010 CW GTI 6sp
anyone have pics of their car on streetlines? thinking about buying them...
rizzogti is offline   Reply With Quote
Old 12-14-2010, 02:21 AM   #14
RSMark5
RSMark5's Avatar
They have the same range of adjustment as all FK's. They will sit anywhere in that range from .5" lower than stock, to around 4" lower than stock.
