HSBREVERSEDSUKS
Hi Guys, we are excited to announce our launch of "FENDERBANDS" for the MK6 platform!
What is a Fenderband?
A fenderband is a customizable stripe kit for your vehicle. We have done the proper measurements and worked our kits to follow the beautiful lines of the MK6 platform!
Any Color Options?
Yes, you have a choice of either a single, double or triple stripes in the following color options: Matte White, Matte Black, Matte Met. Blue, Matte Cardinal Red. (Optional: Carbon Fiber & Brushed Aluminum Kits now available)
Example: (Single Kit) All Matte Blue Stripe
Example: (Double Kit) All Matte Black / Additional Matte Red Stripe
Example: (Triple Kit) All Matte Black / Additional Blue / Additional Black
(You can mix and match any color option that we offer above)
What is a "Wrapping Cast" Material?
"Wrapping Cast" material consists of a multilayered cast 3mil PVC and a release liner with HEX'PRESS adhesive. It is a high-performance cast vinyl for vehicle marking and full wraps. Due to its thickness, it preserves its color even under strong deformation. It is convenient and effortless to apply and remove. The HX20000 makes application easy due to its structured adhesive that facilitates air egress.
Benefits: No Bubbles! Conformability to your fender surface and curves!
Are they customizable? Yes, you can add an additional logo to your stripe kit! We offer GTI / MK6 / TDI / And we can work on a custom logo specifically for your vehicle!
Can the FENDERBAND kit be removed and will it damage my painted surface?
Our kits are made with top of the line "Wrapping Cast" material! It can be removed at anytime with no damage to your vehicles painted clearcoat surface.
(Please note that this should "NOT" be applied to a "FRESHLY PAINTED" surface)
How to Apply?
Applying our FENDERBANDS is just like installing a die-cut decal.. You will want to make sure that the fender surface is clean and dry and is free of contaminants. (We suggest using windex, and microfiber dry) to make sure the surface is both clean and tacky for best adhesion with the wrapping cast material.
You will simply, remove the largest fenderstripe and apply to the first fender. The MK6 has a body line that goes right into the front fender and you will want to apply your front stripe inline with the bodyline.
We provide you with a squeegee, and you will hold the bottom of the vinyl stripe with one hand and "Slowly" squeegee with the other hand to properly bond the vinyl to the surface. We give enough material to trim at the bottom so you can wrap the vinyl underneath the fender for a 100% beautifully installed FENDERBAND!
For customers who choose the second and third stripe kit. You will simply overlay each smaller vinyl stripe over the first fenderband and tuck underneath fender! This makes install a breeze because you can follow the first line of your first installed FENDERBAND stripe.
Note: We will be making a short clip video on how to install your custom "FENDERBAND" kit soon:thumbsup:
Please feel free to contact us anytime with questions or custom logos you would like us to design!
"FREE SHIPPING" is for anyone in the continental US only. Additional charges for Canada and International Shipments
Any Color Options?
How to Apply?
