Old 04-04-2017, 12:38 AM   #1
FlowMK6
FlowMK6's Avatar
Drives: Golf 2.5 6speed MT
Question What lug nuts do I need with TSW Amaroo?
Hi everyone, I don't have the rims yet, but I should get it by the end of the week and I would like to know if anyone knows what is the lug nuts I need ?
1. Conical or seat bolts ?
2. What is the length of the bolt ? 14 x 1.5 x ?
Thanks you and have a nice day
Old 04-04-2017, 02:25 AM   #2
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
Conical
14x1.5x30mm length
I ran the Gorilla small diameter lug bolts, since the TSW's have narrow lug holes, part number: 17019SD-20
http://www.gorilla-auto.com/small-diameter-lug-bolts
2017 Tiguan
Old 04-04-2017, 12:30 PM   #3
FlowMK6
FlowMK6's Avatar
Originally Posted by snobrdrdan View Post
Conical
14x1.5x30mm length
Does the offset could influence the bolt length, I have 18 x 8.5 with an offset of 43
Old 04-04-2017, 01:09 PM   #4
Drives: 10 GTI CSG DSG K04 4DR 153k+
If you get them from a vendor like discounttiredirect, they will include the conical lug bolts. Offset is not typically part of the length, but you should double check how far they thread into the hub. I have the TSW interlagos and the first set of bolts was a little short and only engaged a few threads. I want to say I went to 35mm length but I'd have to pull one to check.
Old 04-05-2017, 02:35 AM   #5
FlowMK6
FlowMK6's Avatar
Conical
14x1.5x30mm length
Where have you found the length ?
Finally I ordered the lug bolt on tdotperformance, I asked the last owner and with his measurement, he told me 30mm too.
Old 04-07-2017, 01:56 AM   #6
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
Stock length is 27mm, but I ran the 30mm's for additional insurance/little extra length for more thread engagement
2017 Tiguan
Old 04-08-2017, 06:18 AM   #7
FlowMK6
FlowMK6's Avatar
Finally on Tdotperformance, they don't have the bolts in stock, so it's a special order and it at take 2 mounts to receive my bolts... So I asked tdot to cancel the order and get refund, I will have to find a Canadian Store where they sell 14 x 1.5 x 30 conical, tomorrow I will ask a local shop if they have bolts in stock. I should have the new rim tomorrow.
Old 04-08-2017, 07:50 AM   #8
Blakcard
Blakcard's Avatar
BMW 6 series lugs might fit. Had a buddy of mine run their black lugs on his Gti. Give your local spot a call?
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old 04-08-2017, 07:02 PM   #9
FlowMK6
FlowMK6's Avatar
Finally I got the bolt at a shop from Levis called BestBuy auto parts (not the electronic store ^^)
I ordered adjustable rear camber arms to correct the camber before installing the rims and tires.
Old 04-09-2017, 07:53 AM   #10
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
What suspension are you running?
Unless you're running air or something, that you need extra camber to tuck, the rear camber is adjustable with the factory bolt
2017 Tiguan
Old 04-10-2017, 02:31 PM   #11
FlowMK6
FlowMK6's Avatar
I'm on coilovers 2.50" front, 2.75" rear. The last owner of the rims and tires have a MK6 GTI with the same setup, he had a little camber, but all the tire got camber used (he did a rotation), so I don't want to take chance with the brand new tires. And what bolt are you talking about ?
Old 04-11-2017, 02:32 AM   #12
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
It's eccentric
2017 Tiguan
Old 04-20-2017, 07:49 PM   #13
FlowMK6
FlowMK6's Avatar
Installed the rims today and forgot that I need hub centric rings, I don't know what size I need, do you know what would be a good size for the centric rings, any recommendations ?
Thanks you and have a nice day,
Kind regards.
Old 04-21-2017, 02:14 AM   #14
snobrdrdan
snobrdrdan's Avatar
Drives: a VW
TSW's take 72.1mm rings & 57.1mm for your car.
I have a set of 4, brand new, from my old TSW wheels if you want them
2017 Tiguan
