Old 04-05-2014, 12:35 AM   #15
Shep
Drives: 2013 Wolfsburg GTI
This guy figured it out without removing wheels... should work on VW caps.
https://www.youtube.com/watch?v=akd2q-S6jZw
Shep is offline   Reply With Quote
Old 04-05-2014, 02:03 AM   #16
ChrisChen1990
ChrisChen1990's Avatar
Drives: 11' GTI 2-door
Well, taking off the centre cap using this method you have to spend $$, but taking off the wheel and then remove the centre cap won't spend you $$, just need patience. This is a really good idea though.
APR Stage 2, SPM street downpipe, Neuspeed cat-back, K&N air intake,Forgemotorsport quick shifter Koni coilovers, H&R 26mm FSB, 22mm RSB, StopTech brake lines, EBC red stuff brake pads, O.Z Opera II, CTS turbo oil catch can, Unibrace UB, R8 coil packs, P3 car gauge, BSH throttle body pipe, Synapse DV, RSR Clutch
ChrisChen1990 is offline   Reply With Quote
Old 06-03-2018, 12:13 AM   #17
Blakcard
Blakcard's Avatar
hmmmmmm
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old 06-03-2018, 12:20 AM   #18
Blakcard
Blakcard's Avatar
So i grabbed my drill 7/54 bit, drilled 2 holes.. rounded out and put in the plastic wheel lug cap remover.. slight tug and its out.
Aftermarket wheels... i know i wouldn't do this to OEM lugs.. i did it ti pull the center caps out to silicone on the VW wheel stickers.
Sent from my SM-G930W8 using Tapatalk
