Old 09-21-2018, 11:47 PM   #1947
ksandman
ksandman's Avatar
Drives: 2013 gti
Originally Posted by ce4 View Post
I'm running Stratified Stage 1 with 91/93 octane tunes. Currently only have a drop in filter and GFB DV+. Thinking about pulling the trigger on an intake. Would I need to get the tunes refined for the intake or will the computer+tune "learn"?
Tuning is recommended. You could probably get away without a tune if you used an intake that uses the stock maf housing but if you got a Cobb intake or something similar you should get a tune
ksandman is offline   Reply With Quote
Old 09-28-2018, 11:40 AM   #1948
pdan
pdan's Avatar
Drives: 2009 VW Jetta TDI (sold), 2013 GTI
Anyone here with p0491 secondary air injection for CBFA code pop up?? It happened yesterday and today, after a shop replaced my rear main seal. Iíve been reading through a few threads on here. It seems to be an issue with the secondary air injection system. Iíve got a Unitronic intake with the second filter. Iím guessing something got pinched or maybe missed when my intake was taken out or put back in? Going to try and figure out if everything was put back together correctly today.
CW 2dr 6MT-Stratified Tuned-Unitronic Intake-Southbend Stage 2 Daily-R8 Coils-NGK Plugs-ECS Tuning 3in Catted Downpipe-Neuspeed Catback-ECS Tuning Dogbone Mount-Unibrace UB-GFB DV-OEM LED Dark Cherry Tails
pdan is offline   Reply With Quote
Old 09-28-2018, 12:38 PM   #1949
pdan
pdan's Avatar
Also just loaded my stage 2 tune. Freaked me out when I first started the car because it made a crazy high pitched squeal, sounded like maybe from the intake, probably related. But for the fuel trims, I was monitoring and idling it seems a bit high, like 1.15 and even up to 1.2. When I get on the throttle though it drops back to 1.5/1.6 or so. Any issues with the trims idling like that, I believe higher is lean correct, something you really want to avoid??
Old 09-28-2018, 12:58 PM   #1950
smanierre
smanierre's Avatar
The higher the fuel trim the leaner the car is running when following the base map. The fuel trim is what is correcting that, or at least attempting to. Have you checked all your connections. Could be a vacuum/boost leak that is causing that. When you said back to 1.5/1.6, what are you referencing there? If those are your fuel trims then I would think that is a huge issue.
Old 09-28-2018, 01:02 PM   #1951
pdan
pdan's Avatar
I have a suspicion that I have a boost or vacuum leak because I popped p0491 yesterday and today. And Iím measuring LTFT, when I get on the throttle to start moving it drops from 1.20 to 1.05/1.06 sorry, decimal places make a huge difference ha.
Old 09-28-2018, 02:39 PM   #1952
smanierre
smanierre's Avatar
Ok lol, those are much much better numbers. Take a look at the short term trims. My theory is if it's a leak after the turbo, you'll run lean at idle/cruise since there is still vacuum, but once you start boosting you should run rich as the vacuum leak turns into a boost leak. The STFTs should drop down below 1 on a pull if its a boost leak. If that makes sense.
Old 09-28-2018, 03:09 PM   #1953
pdan
pdan's Avatar
Well sometimes it might be the simplest things. I hope it is this time ha. I went digging around and found that the hose that leads off my SAI was not connected to whatever hose this was. I started it up and felt a massive vacuum when I put my hand over it. Sure enough I went back in and had the code again. Attached it back, cleared the code and my idle seems to be back around 1.05. Hoping it stays that way. A little difficult to see.
Old 10-05-2018, 01:13 PM   #1954
Alex@Stratified
Alex@Stratified's Avatar
Drives: MK6 GTI DSG
Since these cars are MAF based any leaks past the MAF will throw off fueling and really every calculation in the ECU so it is very important to make sure there are no air leaks.
Exhaust leaks can also throw off the O2 sensor readings and are secondary to air leaks as a potential issue.
Alex@Stratified is offline   Reply With Quote
Old 10-18-2018, 06:04 PM   #1955
vermontmk6
Drives: 2013 mk6
Wanted to share an update to my Stratified story.
In April I bought a COBB AP and cold-air intake.
The OTS COBB map was a hot mess, but definitely more powerful than stock.
Because of the issues with the COBB map, I ordered a low-torque Stratified tune. Stock clutch started to go. Thanks Lionspaz, whoever you are!
Still throwing codes, never felt 100% right.
P0101 Mass of volumetric Air flow Circ. Range/Performance.
P2177 System too lean off idle, Bank 1
Other codes I don't remember
In goes a Treadstone air straightener, GFB DV+, and PCV was replaced. Took weeks to learn about the air straightener, far too long.
Then I was away for much of the summer, nothing got done. I never got the second MAF calibration tune.
Last month I replaced the clutch with RSR w/ flywheel, and added COBB turbo-back exhaust. Other mods were a Diesel Geek short shifter and a set of Pilot Sport 4S tires. Both have changed the car on their own, although I had to take the tires off as it's 30F at night and Michelin lawyers make it seem stupid to keep them on any longer, even though I wanted ONE DAY with a clean tune with the new exhaust and clutch. Oh well, spring is only six months away, plenty of time to research turbo and suspension upgrades in front of the wood stove.
The Stratified ordering process leaves a lot to be desired, and my mid-September order hung in limbo for several weeks. One of the revised tunes threw my car into limp mode. Turns out I didn't correctly fill out the tuning form with my upgrades. You MUST get the Google Form filled out correctly with your complete list of mods, and it's pretty easy to mess that up. I included my mod list in at least five emails, and I kept getting incorrect tunes emailed to me.
The air straightener is considered a mod, which I didn't find out until today. That sucked.
Couple of revisions later, and we're almost there. In the middle were some tunes ranging from poor to ok. Now that they have the full list of my mods, I'm going to do a WOT log tomorrow and hopefully get this sorted out in the next week or so.
In general, the responses from Stratified were courteous , often confusing, referenced incorrect orders, or poorly worded, leaving me not knowing what was happening next.
I have to say that with all of the miscommunication (on both ends to be sure, I'm no genius) and the sub-par ordering process, both parties have been patient and reasonable. Live and learn, it's business, and customer support is never easy.
They are now super-responsive, in part I'm sure to get me off their back.
A while back I was thinking I was an idiot for not going to the dealer to have all the APR stuff bolted on, and drive away a day later with a much lighter wallet. That would have saved me many hours and a few dollars, but I'm glad I didn't do that, because I trust that Alex and the guys will get me sorted out soon, and the gains, even the ones I've felt with an incorrect tune, are far superior to the OTS COBB tunes, which are fine for most people. Same for the APR-in-a-box setup, it works for fine many people who don't want to spend the time and effort to get the perfect tune for their car.
Thanks to Stratified and everyone in the forums who have offered advice and shared their experiences with this process.
Looking forward to posting again once this is all wrapped up!
vermontmk6 is online now   Reply With Quote
Old 10-18-2018, 10:35 PM   #1956
vermontmk6
Drives: 2013 mk6
I received this today, and am trying to figure out what it means.
"The fuel trims are added together. So the combination of short and long term fuel trims should not exceed about +/-7%."
Let's say my STFT trim readings range from -.90 to +1.25. What is the measurement scale, as in 1.25 of what? Is that even the right way to ask the question?
How do I convert these numbers into a percentage to see if it's within acceptable range?
Seems like I'm missing something obvious here.
COBB datalogging for Subarus mention logging "A/F Learning 1", which reports as percentages. But I don't see any reference to this for GTI's. Do I need to log something else that reports in percentages?
Old 10-18-2018, 11:25 PM   #1957
brobst
brobst's Avatar
Drives: CSG mk6 6MT
1.25 is 25% off. 0.90 is 10% off but in other direction
Sent from my SM-G960U using Tapatalk
Old 10-19-2018, 04:18 AM   #1958
smanierre
smanierre's Avatar
1.25 means the engine is adding 25% more fuel than the map is requesting, my initial guess would be post maf pre turbo leak. .90 means it's pulling back on fueling by 10%, initial guess would be post turbo leak, or if you have meth then you're spraying enough to offset some of the fuel needed, but that's not the case for most people. Ideally though you'd want to be at 1 for both short and long.
When he says they are added, say that your long term fuel trim LTFT is 1.06 and your short term fuel trim STFT is .94. Effectively they are +6 and -6 so when you add the you would get 1 and everything would be ok. The STFT updates really fast though so it would be harder to tell what they are adding to without logs. Hopefully this all makes sense
Old 10-19-2018, 07:11 AM   #1959
brobst
brobst's Avatar
Drives: CSG mk6 6MT
You ltft should settle after enough miles to pretty close to 1.00. If you see more than 5% (0.05+-) consistently in ltft, there is probably some issue that needs to be addressed. I.e., a tune adjustment or hardware leak
Stft move a lot because pedal position changes a lot as you drive
Old 10-22-2018, 10:06 PM   #1960
MmmmmBoost
Drives: 2013 GTI MK6
So I think my refinements are done, had 3 revisions with Jared and everything looks good, waiting to hear back if theres any more room for power. 24 hour turnaround time or less from sending in logs to getting files back. Really happy with Stratifieds customer service.
Ive attached my latest datalog below for anyone that wants to compare or check out.
MK6 GTI DSG Stage 2:
ARM Intercooler
GFB DV+
R8 Coilpacks and NGK Plugs
CTS Catted DP
ECS Intake
Uni Stage 2 DSG Tune
Datalog:
https://datazap.me/u/akash95/mk6-gti...og=0&data=5-24
MmmmmBoost is offline   Reply With Quote
