thanks, brosepheous. So, I would need to jack up the car and get under it to access that or can you reach down? not sure exactly on where that is in relation to the first pic, but I will look.
No sir, you can do this from the top. Just pop the hood, and ratchet away. Easy peasy.
If you can't get it from the top, the bottom would be next, but then you have to remove your belly pan. I would honestly try to get it from the top. You can check today.
