bigshoulders
I was reading the mileage tips over at Fuelly and came across this one that made me go Hmm...:
Which now begs the question, does the GTI have this sort of technology that would cut off fuel from the injectors when decelerating?
Cheers,
Kevin
To Coast in Neutral or Not...
Coasting to a stop in neutral with a modern manual (and in some instances automatic) transmission might not actually save you as much gas as keeping it in gear. Many modern engine management systems sense deceleration and negative load while the car is in gear and cut off fuel from the injectors, allowing the turning drive shaft to keep the engine going. Shifting into neutral while decelerating means the system has to keep the engine running with gas.
Cheers,
Kevin
