From GTi's to TDi's to MB S550s to Ford 3.5 EcoBoosts. Any time I removed the charge piping ( especially at the lowest points of the system) there will be some oil that dribbles out. I'm no saying there's cups of fluid but deffinently a few drops or trickle. From my experience over the years working on automobiles.You are correct if there is a slim coating of oil. However, if there is enough you can pour it out of the tube, then the seals are bad.
A slim coating comes from the pcv system. That system will not cause a puddle of oil to form so badly that it could be poured out.
When there is this much smoke, most often it is from more than just the pcv system.
It is a quick and easy check to pull that pipe and look.
