My idle RPM drops when my A/C is off. Can someone confirm this with their cars? I always thought my idle RPM was consistent whether the A/C was on or off.
idle rpm is higher when a/c is on
Yes. More load on engine so revs increase to compensateMy idle RPM drops when my A/C is off. Can someone confirm this with their cars? I always thought my idle RPM was consistent whether the A/C was on or off.
sounds riight to me. Plus dont forget the fans and spinning too when the AC is on so thats more power draw as well.to expand on this... AC draws from the battery to run. battery reaches a certain low point, if you will, propmpting the computer to tell the engine to make more power for the battery via the alternator.
correct if wrong plz
[emoji106] [emoji106]to expand on this... AC draws from the battery to run. battery reaches a certain low point, if you will, propmpting the computer to tell the engine to make more power for the battery via the alternator.
Wgats the process of getting the stratified tune that you went through or if someone from stratified would like to chime in. I read OP but a little more detail would helpGot my Stratified tune installed today. This feels like a whole new car!
Hmm, I think new tires might be a good idea.
Thanks Alex! [emoji106]
Sent from my SM-G935P using Tapatalk
Thanks Alex! :thumbsup:
Ok cool, i have the cobb ap already so it would be the second link first selection right?Cheers, glad you like it!
If you don't have an AP, you can purchase one here and we include the tune.
http://www.stratifiedauto.com/index.php?main_page=product_info&cPath=209_219&products_id=677
Otherwise you can get the tunes from here:
http://www.stratifiedauto.com/index.php?main_page=index&cPath=209_219
