Old 05-01-2016, 11:15 PM   #15
franco516
franco516's Avatar
Drives: gti
Reviving this old thread but I have had these codes for about two years now. And I can't get rid of them or the CEL.
4 Faults Found:
053295 - Fan Identification Sensor
U102F - 000 - No Communications - Intermittent - MIL ON
053296 - Local Databus
U1030 - 000 - Electrical Malfunction - Intermittent
009576 - Sensor for Ozone Reducing Radiator Identification
P2568 - 000 - Implausible Signal - MIL ON
008577 - Performance Malfunction in Cooling System
P2181 - 000 - - Intermittent
I brought the car to the local VW dealer, they said they would try replacing the whole radiator to fix the issue. I passed on this option for a second opinion.
At my local independent, he said the issue was a sensor and that maybe APR could turn off the codes with a custom Stage 3 flash.
I don't have any issues with driveability or performance. I daily drive, track, time trial, and sometimes autocross this car. And I have never had an issue with overheating or the car going into limp mode.
Should I have the independent replace the radiator or should I try the sensor, 8P4965873A, that goose mentioned? I believe both options would be a dis-assembly of the front end.
Thanks.
were would you buy the sensor from? would you get it from the dealer? because i cant find it anywere.
franco516 is online now   Reply With Quote
Old 05-02-2016, 08:40 AM   #16
rs999
rs999's Avatar
Neither could I. I guess I have to shell out $300 for a new radiator and sensor.
Old 05-02-2016, 01:52 PM   #17
franco516
franco516's Avatar
Drives: gti
Might have to do that too eventually
IG - @francotirador91
Old 05-02-2016, 03:10 PM   #18
AccelaSX
Drives: 2012 Black GTI K04 Autobahn
I had to buy a brand new one a few months ago after mechanic broke the probe on the sensor during FMIC install. Based on the google search the only place where you can buy standalone sensor without the radiator is in Russia, go figure why. Russian GTI model is different from CBFA and are not required to adhere to same strict emission standards.
AccelaSX is offline   Reply With Quote
Old 05-02-2016, 03:48 PM   #19
franco516
franco516's Avatar
Drives: gti
but it worked right? you bought a new radiator and the CEL never came back?
Old 05-02-2016, 04:00 PM   #20
AccelaSX
That's right. Though I made some changes before attaching new sensor to the radiator. The radiator and sensor are separate in the box. VW designed this thing in the ways that once sensor is attached to radiator, it's virtually impossible to remove sensor without breaking the probe (some members were lucky in doing just that). I used this opportunity to drill out threads/barbs in the hole where sensor probe goes, so if needed I can remove sensor without braking the probe if need to. I used thermal paste to ensure the heat transfer since the hole is now slightly larger. It has been 5 months now, no CEL and no issues so far.
Old 05-02-2016, 04:03 PM   #21
AccelaSX
I will be in Russia this July, maybe I should just pick a few of these standalone sensors to help a few members not to spend money on the new radiators.
Old 05-02-2016, 05:15 PM   #22
Dr Dad
Dr Dad's Avatar
Drives: 2012 CSG 6sp GTI
Please do!
'12 CSG 6sp | Stage 2 | Intake | Downpipe | Clutch Kit | TOP | DV+ | Springs | RSB | S3 Shifter | FMIC | Catback | My Car
Dr Dad is offline   Reply With Quote
Old 05-02-2016, 10:45 PM   #23
franco516
franco516's Avatar
Drives: gti
great, might honestly pick up a radiator from a junk yard. what are the odds it would have the same issue?
Old 05-03-2016, 08:58 AM   #24
AccelaSX
There are not that many people who have issues with the sensor as you might think. Most of the people like me broke it by accident during installation of FMIC.
So i think it should be safe to pick one up from a junk yard, but make sure that sensor is physically OK.
Old 05-03-2016, 04:29 PM   #25
franco516
franco516's Avatar
Drives: gti
yeah no one that i know has this issue, just me
Old 05-03-2016, 05:35 PM   #26
AccelaSX
Ah, just wait.. as our cars get older - problems will start to appear
Old 05-04-2016, 01:53 PM   #27
goose
Drives: Stage 2 GTI
Well I got my sensor installed, turns out the older one which I assume is for a mkV has a shorter wire
If I had time I would have picked up some connectors and made a proper extension but I spliced in some wire from the bad one. Turns out the wire was crushed causing the intermittent short. No idea when this could have happened ad my car has been to multiple dealerships and has had some front end damage both from Street parking and hitting snow berms at speed., either way it was enough to get rid of the CEL and let me pass inspection.
Sent from my XT1575 using Tapatalk
WHAAAAAAAAAAAAAAAAA TSUTSUTSUTSU
goose is offline   Reply With Quote
Old 05-04-2016, 02:01 PM   #28
goose
Drives: Stage 2 GTI
The one I installed was 8P4965873A and the one that was on the car originally was 873B
