yunone
I installed a magnaflow exhaust tonight and i have some rubbing/resting issue.
After the muffler itself the pipe bends and works it way backwards and is resting on that middle bar which is causing slight vibration to be felt in the car and when you turn off the car you can hear a clunk.
For those that installed the exhaust yourself, how did you get the system to not rub this bar that goes across the car? I loosened and adjusted as much as i could and no matter what they always touch.
thanks in advance
thanks in advance
