Old 01-19-2012, 12:47 PM   #1
lour32
Drives: 06 VW K04 Passat
A true oil separator system!
Using the famous Provent 200 Oil Separator. Can be used for FSI and TSI based cars. Uses OEM Quick-Connects to connect to PCV (FSI), TSI would be different. Here is a CAD drawing & a pre-production part:
lour32 is offline   Reply With Quote
Old 01-19-2012, 01:01 PM   #2
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
hmmm interesting, but you're gonna have a hard time breaking the saturated market unless you offer a damn good price.
I like the idea and depending on price, I might be interested for the TSI.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 01-19-2012, 03:50 PM   #3
BoomBoy
Drives: 2017 Shelby GT350
I feel stupid for asking this but what is an oil separator?
BoomBoy is offline   Reply With Quote
Old 01-19-2012, 03:56 PM   #4
allset
allset's Avatar
someone is working on a catch can provent combo. I guess u could use the provent instead of the oem seperator. i understand it has a filter to absorb crap and doesnt need to be emptied.
How does this currently mate to the TSI?
Old 01-19-2012, 04:06 PM   #5
grambles423
Limited Activity
Same thread posted on golfmkv with the same concerns
http://www.golfmkv.com/forums/showthread.php?t=161958
Old 01-19-2012, 04:27 PM   #6
Bender
Bender's Avatar
Drives: 2014 Focus ST
tag me as interested in a TSI version.
Old 01-19-2012, 05:05 PM   #7
lour32
Bracket you see pictured is what would be used in the TSI application as well, but it would not use the PCV valve cover plate like the FSI, but instead be used in combination with your stock setup, capping off rear outlet of you stock PCV system and running the Provent to the OEM fitting on your stock or aftermarket intake. Been contemplating whether or not to remove the TSI stock PCV and put a custom plate in its place but I am trying to keep this thing affordable and alot cheaper! The TSI setup is actually going to be cheaper than the FSI line due to less parts.
Old 01-19-2012, 06:20 PM   #8
corrado917
corrado917's Avatar
Drives: GTI CSG
When?
How much?
Group buy?
Old 01-20-2012, 04:17 AM   #9
signowell
Drives: Nissan
I see these upper pictures really very nice to use. I like it.
Drum Chandelier Shades
signowell is offline   Reply With Quote
Old 01-20-2012, 10:04 PM   #10
1badChalupa
1badChalupa's Avatar
Drives: Sabre GT, NRG-900
An oil separator or oil catch can takes over the function of the PCV (positive crack case ventilation) system. What happens is, while an engine is running, and combustion is taking place, some times gases blow by the piston rings and into the crank case. This needs to be vented. As an environmental concern, these especially noxious gases are routed back into into the engine to be burnt. Things like oil make there way back in as well- not great for engine performance. The separator intercepts this line and traps the oil in a can (the catch can).
If you outlaw chalupas, then only outlaws will have chalupas.
1badChalupa is offline   Reply With Quote
Old 01-20-2012, 10:14 PM   #11
ka_killuh
Drives: 2013 CSG GTI Autobahn
The real benefit of an oil separator is the lack of catch can.
A traditional catch can system traps the oil that's suspended in your PCV system in a large can, forcing you to drain it and throw it away.
An air oil separator pulls the oil out of the air in your PCV system then drains it back into your crankcase. No need to ever drain it and no loss of oil.
When you are driving normally, oil begins to accumulate and circulate through the PCV system. When you nail the gas and the turbo spools up, a large amount of oil is pulled into the cylinder and burned. What we are trying to prevent is the oil being pulled into the cylinder, thus lowering the effective octane once it mixes with the fuel inside.
ka_killuh is offline   Reply With Quote
Old 01-20-2012, 11:11 PM   #12
allset
allset's Avatar
is this ready to go for the TSI as a complete kit? my interest is def piqued.
Old 01-20-2012, 11:13 PM   #13
allset
allset's Avatar
what about water vapor/condensation? that goes back in too?
Old 01-20-2012, 11:34 PM   #14
ka_killuh
It's already in your crankcase. There is moisture in the air all around us. I am more worried about spark knock due to oil mixing in the combustion chamber w/ fuel.
