Get the brightest LED for your trunk with no hassle at our low introductory price. [THIS FITS ALL CAR MODELS]
To purchase:
http://deautokey.com/product/universal-48-led-flexible-strip-for-your-trunk-fits-all-car-models
We did the research, and created the best and brightest LED for your trunk, our 48 LED Strip simply lines your trunk, with either 3m tape or velcro which are both included.
This is the best solution for a dark trunk, easily installs and hides:
-Plug & Play
-Error Free
-48 Bright White LEDs (Also comes in red)
-Enough LEDs to light up your entire trunk but short enough to fit any trunk, can install vertically or horizontally.
-Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
-Strong 3M tape & Velcro so you can install on any hard surface or trunk lining (please use a blow dryer to heat the 3M glue and cold metal, this will activate the glue)
-Resistor which allows for the light to stay on and not dim if your dome lights shut off while trunk is open. This feature is a must have, it allows for a bright continuous light at all times.
-Trunk LED will not stay dimly lit when your car is off.
-Comes with 3 adapters: Wedge, Adjustable Festoon, and Bayonet, this will fit every trunk adapter on the market.
Actual LED strip measures: 31 inches – this length will fit all trunks, can install vertically or horizontally.
Black Wire measures: 52 inches – please note- excess wire simply tucks into your trunk’s housing/lining so you will not have any leftover in your trunk.
Includes:
1 LED strip with strong 3M tape attached
3 Adapters (Wedge/festoon/bayonet)
3 Pieces of velcro
