ACHILLES R32
Can you elaborate on the rear USB plug all the 187b I have seen have no usb in the rear. Unless you solder the USB to the PCB. I wouldn't mind swapping by no name 187b for a upgraded unit with built in USB in the rearI love the RCD 330 unit absolutely amazing.
I would recommend buying the latest 187 version comes with carplay, android auto and a rear usb.
And also newest Noname version has ability to update firmware and mess with custom firmware
I have the 187B version by Desay and I don't get android auto (no biggie for me since apple)
And I also had to solder directly to the unit's PCB to get a rear usb.
This process makes the front USB not usable but can regain functionality if unsolder rear usb and revert.
I'm going to have to reopen the unit to add a rear aux so I'll take pictures.
The unit is responsive 99% of the time, I did have it shit bricks once were it started lagging like crazy but resolved itself on next start up after a few minutes off.
With apple carplay and android auto its mainly a dock for your phone so I would imagine performance in these areas to be limited to your device to some extent.
If your not using these features its still a decent radio but nothing too special.
I had an android head unit before this and absolutely hated the laggy and inaccurate gps. Now I can use google maps through carplay and much better.
Steering wheel controls all work, however it took my unit a day before they started working. Not sure if it went through some learning process or what. I do not use the unit as a phone charger as it does not have fast charge capabilities, It will give you some juice when using carplay but I have a fast charge usb port in my 12V outlet to survive those critical moment, at those points I just connect to unit through bluetooth.
The unit has built in bluetooth that does not talk to the cars bluetooth, assuming you already have a bluetooth equipped car. I believe this disables the answer call button near the sunglass holder? I haven't tested usually don't answer calls when driving. I have taken a call with the unit once and they had no problem hearing me.
Sent from my Pixel 2
