Plaidshadow
I can fully roll my window down but when I press for the window to go back up, it either doesn’t respond or only slight goes up increments.
I found that by parking the car, switching the ignition off, and then turning the key forward (power only - no starting) and then opening and closing the door, the window goes up slightly. I repeat opening and closing the door and pressing the window button “up” until I get the window up. Other windows appear to work fine.
Could it be the following;
1. Window motor problem ?
2. Fuse ?
3. Weak battery ? (I have not disconnected the battery lately)
4. Pinch protection issue?
5. Some Secret GTI button sequence I need to do to reset ?
Any thoughts might help before I bring it in. Car is a 2010 GTI Autobahn Edition 4D DSG. Thanks!
2. Fuse ?
