Old 07-23-2018, 08:03 AM   #127
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Afr you just making sure you arent lean in pulls. Number should be smaller than 14.7 when wot.
Fuel trims you are looking for ~1.0. It shows if car has to add fuel or subtract fuel from requested. Greater than 1 I believe its trying to add, less than 1 take away fuel. More just shows how your car learns
Sent from my SM-G960U using Tapatalk
Old 07-23-2018, 05:05 PM   #128
cgj_mk666
Drives: 2011 GTI 6MT.
Thank you. I appreciate it
Cobb AP. Stratified Tuned. Godspeed FMIC. H&R Sport Springs. Autotech/Sachs struts. ECS Strut mounts. 034 Track Density mounts. S3 control arm bushings. H&R/Eibach sways, EBC rotors. Custom Intake and Turbo-back. Continental ExtremeContact Sports
cgj_mk666 is offline   Reply With Quote
Old 12-13-2018, 11:50 AM   #129
Tony48
Tony48's Avatar
Drives: 2011 GTI / K04 / 6MT
Trying to figure out launch control but can't get it to work. I have read the info on the Cobb website (here and here).
Flashed to the most up to date (v106) OTS Stage 2 / stock MAF / 93oct tune and following these steps for 6MT:
  • Depress and hold the clutch pedal to 100%
  • Move the shifter to 1st gear
  • Depress and hold the gas pedal to 100%
  • Once the rev limit has been reached, release the clutch pedal
Rev limiter doesn't kick in and the engine revs to red line. What am I doing wrong? Can't get burnout mode to hold RPM either.
EDIT: Figured it out. I wasn't putting the pedal to WOT quickly enough. You can't ease into the throttle, you have to go WOT before the RPM's get to your launch control limit.
| 2011 GTI - P&P K04 - Stratified ProTune | Build Thread| Timing Chain Replacement Tips | DIY RSR Clutch & RMS Replacement Tips|
Tony48 is online now   Reply With Quote
Old 02-08-2019, 10:41 AM   #130
rawag77
Drives: 2013 GTI Autobahn
Are you guys still experiencing the Accessport randomly detecting the engine is off and rebooting even when the car is running/moving? I know this has to do with the Auto On/Off feature and it was recommended by Cobb to turn that off, but what's the fun in that. Just checking to see if there was ever a fix. As far as I know, I have the latest firmware, but it still happens to me on a daily basis. 3 times on my 30 minute commute home yesterday.
rawag77 is offline   Reply With Quote
Old 02-08-2019, 07:25 PM   #131
theclutch
theclutch's Avatar
Drives: Mk6
This happens to me also. But it does start back up. The only thing I "lose" is whatever was the max value on the gauges when it went out - which is no big deal.
theclutch is offline   Reply With Quote
Old 02-12-2019, 12:59 PM   #132
kiyoshi147
kiyoshi147's Avatar
Drives: 2013 GTI DSG 4 Door w/Nav
I had this issue with when the Auto On/Off was enabled. It happened far less often with the Auto On/Off disabled. Sent it back to Cobb, they looked at it and sent me a new one.
Continued to run with Auto On/Off disabled for a while with few reboot issues, and recently switched back to Auto On/Off enabled and haven't noticed a real increase in the frequency of the issue.
I drive at minimum an hour each way to work, so I have gotten a reasonably good sampling time. Never got a firm answer from Cobb as to why it was doing this though. They couldn't find a reason, hence just sending me a new accessport.
In other news, still waiting for the max temp value for Oil (Sump) and Coolant (and probably a few other monitors) to be brought down from the 3000 or whatever value it switched to on a firmware update a while ago. hard to really see the difference on the bar graph between 50 and 220 when the graph scale is from -300 to 3000.
kiyoshi147 is offline   Reply With Quote
Old 07-14-2019, 09:55 PM   #133
speeding_ant
Drives: 2011 Golf GTI
Looks like Cobb have updated the AP to support a few more world market Mk6 GTI ECUs. Also, they've said they are still working on a DSG tune for our cars... cross fingers...
speeding_ant is offline   Reply With Quote
Old 10-03-2019, 03:14 PM   #134
synthetikv
Drives: 13 GTI Driver's Edition
anyone know if stratified stage 2 will clear the cel with cts downpipe or will i need a spacer or something?
also any word on dsg tune for us? i'm about to pull the trigger, but not stoked on having to get dsg tune elsewhere
synthetikv is offline   Reply With Quote
Old 10-03-2019, 03:17 PM   #135
uglybastard
uglybastard's Avatar
Drives: VW Mk6 GTI 3 pedal in CSG
just a spacer should get rid of the CEL.
..246.............. Insta: PSSMKLLR.MK6
uglybastard is online now   Reply With Quote
Old 10-03-2019, 03:23 PM   #136
synthetikv
yeah I get that, but wondering if tune will clear it. I had apr on my mkvi gli and tune got rid of downpipe cel. Just wondering if stratified tune will do the same for the cts dp.
Old 10-03-2019, 03:28 PM   #137
uglybastard
not without a spacer. spacer with no tune i had no issues. tune will help too but not needed. tune with no spacer usually results in CEL.
Old 10-03-2019, 08:14 PM   #138
synthetikv
kk thanks!
Old 10-03-2019, 08:38 PM   #139
SC_MK6
Drives: 2012 csg gti autobahn
Not sure about their OTS map but I used to have a Stratified k04 protune and Alex disabled the rear o2 sensor code so I wouldn't get a CEL.
Sent from my SM-N950U using Tapatalk
SC_MK6 is offline   Reply With Quote
Old 10-04-2019, 08:40 AM   #140
fbgmoney
Drives: 2014 CW GTI DSG
Cobb responded on the other day on reddit when asked about a mk6 dsg tune.
"Maybe one day. Just a lot of other stuff going on atm. Too many projects, not enough resources."
fbgmoney is offline   Reply With Quote
accessport, accesstuner, cobb, cobb tuning, tune
