Old 06-21-2018, 06:29 PM   #15
smanierre
smanierre's Avatar
Originally Posted by vermontmk6 View Post
Stock turbo for now. Currently waiting for Stratified to send me the final MAF tune. Clutch slips like a mofo on the low-torque 93 octane map.
Clutch, brakes, COBB cat-back exhaust, Stage 2 retune , then deal with charge pipes and smaller stuff, then maybe bigger turbo once everything is settled down.
I've been trying to pick a LSD from the various models, need to read more drivability reports on the two main vendors.
Thats basically the same plan i'm following, currently on the charge pipe portion. I just got a SB stage 2 endurance and peloquin LSD. Was able to floor it in second all the way to redline and only got a slight bit of wheel hop, thats also probably from the mounts and fat tires but im sure the LSD helped as well.
Old 06-28-2018, 01:49 PM   #16
vermontmk6
Drives: 2013 mk6
Why not Stage 2 Daily Driver? I'm considering that or endurance, which seems like more than enough clutch.
vermontmk6 is offline   Reply With Quote
Old 06-28-2018, 02:43 PM   #17
smanierre
smanierre's Avatar
The shop recommended that so I just went with it. It was really stiff at first but now it really doesn't feel that stiff. Doesn't like bad shifts but feels amazing on good shifts
Old 11-07-2018, 11:53 PM   #18
theclutch
theclutch's Avatar
Drives: Mk6
Ok guys... add me to the list of people with this surging issue. Bought the airflow straightener (frankly pretty annoyed my Cobb $395 intake now became $430 with this air straightener thing). That's $105 more than the APR at this point (dunno if the APR one suffers the same issue).
Installation wise, I just put mine at the very edge of the tube. Do I really have to put it as close to the MAF as possible? I guess I could just try it and find out.
I'm also getting what sounds like tires rubbing from 72 to 75 miles per hour. This is not dependent on RPMs. I could put the car in neutral at that speed and still get the sound. It's annoying that I typically cruise at that speed. So I find it ironic that I get the drone from the intake and not from the downpipe! I can change the sound a little bit by removing the top cover and reorienting the intake filter one way or another. Has anyone else noticed the same issue?
theclutch is offline   Reply With Quote
Old 11-08-2018, 05:29 PM   #19
Slowgti08
Slowgti08's Avatar
Drives: 2008 VW GTI
Thumbs down
That sucks bro.. Sorry to hear that.
Old 11-10-2018, 09:57 PM   #20
theclutch
theclutch's Avatar
Drives: Mk6
Which LSDs are you considering?
Also, add me to the list of fixed COBB intakes... that MAF air straightener worked wonders!
https://www.golfmk6.com/forums/showp...15&postcount=7
Old 02-20-2019, 11:28 PM   #21
Donutman
Drives: 2013 gti
Getting the same codes .
Cobb stage 1+
Sf cobb intake
Ie fds Intercooler
Ie catch ca.
The question is what size inserts 3 or 3.5
Donutman is offline   Reply With Quote
Old 02-21-2019, 08:14 AM   #22
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
It's easy, order your size off of Treadstone's website. You can equally crush the outside of the straightener until it fits inside the pipe. Throw a tac or two of super glue and you're done. The car will run much more smoothly. A lot of us do this with custom big turbo intakes.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 02-24-2019, 04:58 PM   #23
vermontmk6
Drives: 2013 mk6
Thanks for these great photos, yeah it took me a while to learn about the airflow straightener, COBB said nothing.
Old 02-24-2019, 08:27 PM   #24
theclutch
theclutch's Avatar
Drives: Mk6
It's a travesty and BS that we have to add this "straightener" to make their intake work. Had they admitted to it, they would have had to admit to the poor engineering on their part. Also make note how you get a "tire rubbing" sounding noise even with the straightener between 72-74 mph; worse without it. It's utterly poor design AND poor testing on their part. I can't say how any one else's intake is. But this one is unacceptable for the price. If it was a $200 intake, that's one thing...But for what amount to $430? I would have tried the APR (which could, to be fair, have it's own issues).
Old 02-25-2019, 08:49 AM   #25
vermontmk6
Drives: 2013 mk6
I put the LSD research on hold. I'm going to replace the COBB intake with maybe one from IE to get rid of the straightener. Been going back and forth between k04 and BT, k04 is winning right now.
Old 02-25-2019, 10:51 AM   #26
hbrown0509
hbrown0509's Avatar
Drives: 2013 VW GTI 4DR DSG
The IE intake is a solid choice! I like it the most out of the other ones.
Old 02-25-2019, 11:36 AM   #27
theclutch
theclutch's Avatar
Drives: Mk6
Before you get an IE intake, run the COBB intake without the top cover. You may/may not like the sound of an "open air" element filter. It poses its own set of challenges.
Old 02-25-2019, 12:19 PM   #28
smanierre
smanierre's Avatar
+1 for IE. I went from forge to Cobb to IE and the IE is the only one I didn't get weird behavior with. Also I would say go gtx2867. Will still perform well at near k04 levels of power but still gives you room to grow if you want and will have a good response due to it being on the smaller end.
cobb, intake, stratified, tune
