Old 08-18-2019, 09:25 PM   #1
flight1us
Drives: Mk6 VW GTI
Throttle Body
Time for a new throttle body?
Below you will find my recent scan on VCDS for a few codes in regards to my throttle body.
Any input would be greatly appreciated.
Address 01: Engine Labels: 06J-906-026-CCT.clb
Control Module Part Number: 1K0 907 115 AP HW: 1K0 907 115 AA
Component and/or Version: 2.0l R4/4V TFSI 0040
Software Coding: 0403010A1C070160
Work Shop Code: WSC 00001 000 00000
VCID: 74B1213262BCA067DE1-8020
3 Faults Found:
000546 - Angle Sensor 2 for Throttle (G188)
P0222 - 000 - Signal Too Low - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 28.0C
Temperature: 30.0C
Absolute Pres.: 1010.0 mbar
Voltage: 8.763 V
000545 - Angle Sensor 2 for Throttle (G188)
P0221 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 172356 km
Time Indication: 0
Date: 2019.08.07
Time: 20:40:28
Freeze Frame:
RPM: 1209 /min
Load: 12.2 %
Speed: 0.0 km/h
Temperature: 25.0C
Temperature: 24.0C
Absolute Pres.: 1000.0 mbar
Voltage: 11.684 V
000289 - Throttle Position Sensor (G69)
P0121 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 172361 km
Time Indication: 0
Date: 2019.08.10
Time: 18:58:05
Freeze Frame:
RPM: 1522 /min
Load: 28.6 %
Speed: 3.0 km/h
Temperature: 94.0C
Temperature: 54.0C
Voltage: 13.843 V
Readiness: 0010 0001
CW '11 GTI DSG/APR Stage 2 ECU /APR Stage? TCU/Unitronic CAI/ HPA K04/18" Detroits/H&R Coilover kit
flight1us is offline   Reply With Quote
Old 08-19-2019, 09:23 AM   #2
flight1us
Drives: Mk6 VW GTI
45 views no help ... Thanks
Old 08-19-2019, 06:20 PM   #3
BudgetPhoenix
Drives: 09 GLI
Theres a TSB out for the throttle body where the TB wiring become damaged over time causing a slew of codes including all the ones you posted or it could be an actual bad throttle body itself or some other wiring issue. Hard to
diagnose exactly without VCDS and a multimeter.
Read about the TSB referenced in this topic.
https://www.golfmk6.com/forums/showthread.php?t=97264
Old 08-20-2019, 02:48 PM   #4
flight1us
Drives: Mk6 VW GTI
diagnose exactly with VCDS and a multimeter.
Thanks i appreciate the response.
Old 08-20-2019, 03:00 PM   #5
jay745
jay745's Avatar
You could also try doing a throttle body alignment with vagcom before putting a new one on.
https://www.youtube.com/watch?v=2zrmhDw_v7Y
MK6 K04 GTI Build Thread
improvise. adapt. overcome
Old 08-20-2019, 03:24 PM   #6
flight1us
Drives: Mk6 VW GTI
Others are telling me it could also be the Accelerator pedal that went bad.
Old 08-21-2019, 09:03 AM   #7
flight1us
Drives: Mk6 VW GTI
tried doing the vagcom alignment and it errored out.
Old 08-22-2019, 11:12 AM   #8
flight1us
Drives: Mk6 VW GTI
Does anyone know the part # for the repair wires associated with Throttle body connection repairs?
Old 08-22-2019, 11:41 AM   #9
Tony48
Tony48's Avatar
Drives: 2011 GTI / K04 / 6MT
I assume it is the same wire used for wiring in a euro headlight switch. 000979009E
| 2011 GTI - P&P K04 - Stratified ProTune | Build Thread| Timing Chain Replacement Tips | DIY RSR Clutch & RMS Replacement Tips|
Old 08-23-2019, 12:40 PM   #10
flight1us
Drives: Mk6 VW GTI
Thanks man i appreciate it., if anyone know if the throttle body plug can be supplanted from another wiring harness ? thanks
Old 08-25-2019, 06:28 PM   #11
flight1us
Drives: Mk6 VW GTI
Code:
Friday,16,August,2019,19:28:57:30972
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWHV7AJ5BW125046   License Plate:
Readiness Status: 0010 0001
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
Sunday,25,August,2019,17:14:37:30972
www.Ross-Tech.com
                Address 01: Engine  (1K0 907 115 AP)
17:14:34 Group 060: Electronic Throttle (Throttle Body Alignment)
  16.0 %  Throttle Valve Sensor 1 (G187)
  0.0 %  Throttle Valve Sensor 2 (G188)
  0  Throttle Valve Steps Counter
  ERROR  Throttle Body Alignment Status
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHV7AJ5BW125046   Mileage: 172380km-107111miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AP    HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH18---    Serial number:
   Shop #: WSC 00001 000 00000
7 Faults Found:
005497 - Throttle Actuator (J338)
               P1579 - 000 - Adaptation Not Started
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.20
                    Time: 19:01:08
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 62.0C
                    Temperature: 39.0C
                    Voltage: 12.192 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.20
                    Time: 19:01:08
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 62.0C
                    Temperature: 39.0C
                    Voltage: 12.192 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 000 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.25
                    Time: 13:26:17
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 21.0C
                    Temperature: -40.0C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 12.192 V
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 23.0C
                    Temperature: -40.0C
                    Voltage: 12.319 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 000 - Circuit Open - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.25
                    Time: 14:03:53
             Freeze Frame:
                    RPM: 215 /min
                    Load: 41.6 %
                    Speed: 0.0 km/h
                    Temperature: 23.0C
                    Temperature: -40.0C
                    Voltage: 10.668 V
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.25
                    Time: 14:05:30
             Freeze Frame:
                    RPM: 1722 /min
                    Load: 28.2 %
                    Speed: 0.0 km/h
                    Temperature: 27.0C
                    Temperature: 30.0C
                    Voltage: 14.224 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
               P2014 - 000 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 35.0C
                    Temperature: 33.0C
                    Voltage: 12.192 V
Readiness: 1010 0101
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 053 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2235
   Revision: 05151112    Serial number: 00001009240436
   Coding: 0000020
   Shop #: WSC 01357 011 00200
   VCID: 20191D6286C46CC7EA9-8074
No fault code found.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B600C492400FF880B06E8921F0041B70800
   VCID: 78A9150272D4C407F29-802C
2 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 54
                    Mileage: 172313 km
                    Time Indication: 0
                    Date: 2019.07.21
                    Time: 21:38:32
             Freeze Frame:
                    Count: 2
                    Count: 14
                    Count: 29440
                    Count: 8193
                    Count: 41984
                    Count: 65025
                    Count: 1024
                    Count: 0
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 172313 km
                    Time Indication: 0
                    Date: 2019.07.21
                    Time: 21:38:32
             Freeze Frame:
                    Count: 2
                    Count: 14
                    Count: 29440
                    Count: 16401
                    Count: 41984
                    Count: 65025
                    Count: 1024
                    Count: 0
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B71C366546B96FE9F-8020
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 L    HW: 1K0 937 086 L
   Component: BCM PQ35  M   104 0615
   Revision: 00104 AE
   Coding: 6D180A3F08272EC4008800817000054440010086534D8D60648020200040
   VCID: 392FD006095E1D0FCD7-806C
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 02101  26  0512
   Coding: 009795
7 Faults Found:
00061 - Footwell Lights
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 5
                    Fault Frequency: 112
                    Reset counter: 56
                    Mileage: 172325 km
                    Time Indication: 0
                    Date: 2019.07.23
                    Time: 18:44:25
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01518 - Bulb for Back-Up Lights; Left (M16)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 129
                    Reset counter: 56
                    Mileage: 172325 km
                    Time Indication: 0
                    Date: 2019.07.23
                    Time: 18:53:26
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01519 - Bulb for Back-Up Lights; Right (M17)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 124
                    Reset counter: 56
                    Mileage: 172325 km
                    Time Indication: 0
                    Date: 2019.07.23
                    Time: 18:53:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01496 - Bulb for Fog-Lamps; Left (L22)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 125
                    Reset counter: 56
                    Mileage: 172325 km
                    Time Indication: 0
                    Date: 2019.07.23
                    Time: 18:53:27
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02394 - Parking Light Left Front (M1)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 37
                    Reset counter: 94
                    Mileage: 172327 km
                    Time Indication: 0
                    Date: 2019.07.28
                    Time: 00:25:07
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
01500 - Bulb for Fog-Lamps; Right (L23)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 172327 km
                    Time Indication: 0
                    Date: 2019.07.28
                    Time: 00:25:16
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.15 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 81
                    Reset counter: 94
                    Mileage: 172327 km
                    Time Indication: 0
                    Date: 2019.07.28
                    Time: 22:22:39
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.40 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R014MK7
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 392FD00609DE1D0FCD7-806C
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--0005C66X00
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME6D116557ZZZ.
   Crash sensor for side airbag: front passenger side:
   Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME5F4D4058ZZZ5
   Crash sensor for side airbag: rear: driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME1E57636EZZZ4
   Crash sensor for side airbag: rear: passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME16486375ZZZW
   Crash sensor for front airbag: driver side:
   Component: F.Sens.Fahr  --- ----
   Serial number: 35527SME75446520ZZZ9
   Crash sensor for front airbag: front passenger side:
   Component: F.Sens.Beif  --- ----
   Serial number: 35627SME61616520ZZZ4
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JIR0008U
   Coding: 189A140000
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B51B3A7840B277E05-8022
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Serial number: 0162024
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 270F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: 3537DC3625C6F96F29F-8060
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 101010F1000509
   Coding: ED807F0600161200000002
   VCID: 6D873456019671AF11F-8038
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RALBF06
   Coding: 0000002
   VCID: 7EA5031A5CF0FA37B85-802A
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3F4A3CF8669774D-803E
1 Fault Found:
9456681 - Key
          B104C 29 [008] - Implausible Signal
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 172382 km
                    Date: 2019.08.16
                    Time: 19:43:34
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Component: SG EXT.PLAYER H13 0111
   Revision: A1001003    Serial number: 7668761487
   Coding: 010000
   VCID: 270B067EEFEA9BFFAB3-8072
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.16
                    Time: 19:34:44
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 313FE826DD2ED54F757-8064
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 323DE72AD828EE570CD-8066
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H13 0043
   Revision: -----26S    Serial number: VWZ4Z7K1162886
   Coding: 0100040004
   VCID: 619F5866C14E25CFA57-8034
2 Faults Found:
00874 - Treble Speaker Front Left (R20)
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 56
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.20
                    Time: 18:11:59
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 55
                    Mileage: 172382 km
                    Time Indication: 0
                    Date: 2019.08.20
                    Time: 18:11:58
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 D    HW: 5K0 959 703 D
   Component: Tuer-SG         007 2101
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 3537DC362946F96F29F-8060
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 D    HW: 5K0 959 704 D
   Coding: 0001168
   VCID: 3635DB3A3440F277205-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668732415
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 323DE72AD4A8EE570CD-8066
End----------(Elapsed Time: 01:13, VBatt start/end: 12.0V/12.0V)-----------
Old 09-08-2019, 08:13 PM   #12
flight1us
Drives: Mk6 VW GTI
so i have not replaced the wiring to the throttle body but i am posting a video link here for those who don't know what the situation is ...https://www.youtube.com/watch?v=90RFIaNfCv8
Old 09-09-2019, 10:35 AM   #13
qwop
Drives: 2013 GTI mk6
My G188 sensor was bad on my throttle body when I got my car. It resulted in 5 or so different throttle body error codes but I dont remember the specific ones. Luckily I had another throttle body so I just changed it and that was the end of that. Why do you think its the wires and not the throttle body sensors themselves?
qwop is offline   Reply With Quote
Old 09-09-2019, 11:32 AM   #14
flight1us
Drives: Mk6 VW GTI
because there is a Technical Service Bulletin that notified of the issue with the codes i included the codes in this thread. take a look it might be similar to what you had.
