I flashed back to Stage1 to test, a lot easier to drive coming off idle and the idle rpm is a tad bit lower.I'll get to try it out in a year or so when I have to put the stock IM back on for the smog check. I'm not planning on changing tunes as stage 2 should pass emissions no problem.
EDIT: Flashing back to the IE Stage1 from Stage2 took ~10 minutes using the IE PowerLink V3 Dongle. If you don't have Ross Tech VDCS, you can use the IE PowerLink V3 to to Clear your OBD error codes as well as Data Log you engine operating data and export to a CSV file, real geek stuff.... or nerd stuff, or whatever.
