jay745
What Would Glenn Danzig Do
IMO - if you're going to replace the rear position control arm bushings you should consider upgrading to Whiteline or SuperPro and take advantage of the added benefits of increased caster / anti-lift. I love my Whitelines and I'm very sensitive to suspension NVH.
https://www.ecstuning.com/b-whiteli...control-arm-bushing-kit-rear-position/kca316/
It's like opening a can of worms. If you're going to replace these control arm bushings then why not drop your subframe while you're at it and replace your worn stretch bolts with TyrolSport deadset kit. This will really sure up the front end and improve your ride.
Powerflex is a much better option over both superpro and whiteline. Adds 8 degrees of caster without offsetting the bushing itself. Cheaper too
