I don't have the 330 yet to know for sure, but as I had mentioned in my other posts based on my reading I keep seeing people mention an incompatibility with Dynaudio where it will "work" but not perfectly as it's actually not using the Dynaudio amp and just using the 330s internal amp. I've only been able to go off other peoples posts (and I've read a lot on several forums) which is why I decided to just dive in and order the thing and find out for myself.
From my reading it seems like if you just plug in the 330 into a car that has Dynaudio and had an RNS315 it will work, but, the volume scaling will be off meaning it will jump through the volume range faster than the 315 and not sound as good at higher volumes. If you try to Vagcom code the 330 for Dynaudio it won't work. When plugged into a car with Dynaudio the 330 fader won't work. If you code it to Skoda amp the fader will work but the audio sounds bad since the output voltage of the headunit is still too hot for the Dynaudio amp.
So based on all that, again, just from my research and reading no real world testing yet, my thinking is if you code it for the Skoda amp and use the Alpine harness I mentioned earlier which will lower the speaker level output voltage to turn on the Dynaudio amp then everything should (fingers crossed) work even better making full use of the Dynaudio amp.
Don't know about all that. All I can say is I'm using a 330 (mostly Carplay) in my 2012 Autobahn GTI with Dynaudio and, to my ears, there was a slight improvement in sound quality over the 315
The only anomaly I experience is the volume jumps after any interaction with Siri. Regular modulation of the volume is perfectly fine.
I suggest buying one and hooking it up to see what works or doesn't. If you don't like it, there is strong resale demand
