Old 03-25-2016, 11:26 PM   #799
jettaglx91
FIA GT Champion
Drives: 450whp TSI GTI, 420whp R, stock CC
Originally Posted by spenny02 View Post
I was just trying to confirm that the logs and display were reading the same. Next log i will do a 3rd pull and a 4th pull. I was thinking that running it through the gears might give some good holistic data.
Long single gear pulls are much better for data
jettaglx91 is offline   Reply With Quote
Old 03-26-2016, 12:35 PM   #800
andysamland
Drives: mk5 gti
There is so much fail in these logs. The really long log that was posted has knock all over the freaking place and the more current logs look solid, but very very weak. like not even hitting 160% load is ridiculous. I know that many of you here don't really know how to dissect what is going on in these logs, but it doesnt look amazing. Theyre missing a few parameters that a pro tuner would need. I still stand behind my initial impressions that they dont know what theyre getting into with the vag scene
Need eurodyne help?
tunemaestro.com - Coming soon
andysamland is offline   Reply With Quote
Old 03-26-2016, 01:03 PM   #801
thebestdj07
Drives: 2011 gti
heres a vid of mine with a atp catless dp on the stage 1 93 high boost
https://youtu.be/SBFu_QJMWoM
thebestdj07 is offline   Reply With Quote
Old 03-26-2016, 01:20 PM   #802
blingdub
Rally Car Champion
Drives: 2011 GTI MK6 Autobahn MT, Uni 1+
no doubt that people are giving cobb some slack being new to the scene. i think what everyone is most interested in is 1) how much improvement can we expect to see from their OTS maps, and 2) how long will it take for them to do that.
if the answer is "go get pro-tuned", then that is the biggest fail of all.
VW '11 GTI Autobahn MT, Unitronic Stage 1+, ECS Luft-Technik Intake, RevD DV, R8 Coil Packs
SPULEN Quick Change Short Shifter Kit, Torque Solution Shifter Cable Bushings, ECS Shifter Bracket Bushings, Raceseng Ashiko
Red LED Footwell Lights, Clutch Stop
blingdub is offline   Reply With Quote
Old 03-26-2016, 01:29 PM   #803
blingdub
Rally Car Champion
Why aren't you running stage 2 if you have a downpipe?
Sent from my SM-T320 using Tapatalk
Old 03-26-2016, 02:19 PM   #804
MMKAY6
Drives: 2013 GTI Autobahn
Second time I've done that in the last two hours lol. They had the ccta updates for my engine.
Mind sharing the link to the CCTA maps? Been looking all over their site and only see CBFA maps.
2013 GTI Autobahn | COBB Tune (since 3/22/16) | Nothing else
MMKAY6 is offline   Reply With Quote
Old 03-26-2016, 03:19 PM   #805
thebestdj07
Drives: 2011 gti
stock intake still.
Old 03-26-2016, 03:37 PM   #806
jm090
Drives: 86 GTI, 09 GTI
stock intake still.
You can run a stage 2 with a stock intake.. You can run a stock intake on ko4 even some people say.
Sent from my SM-G925V using Tapatalk
jm090 is offline   Reply With Quote
Old 03-26-2016, 03:56 PM   #807
thebestdj07
Drives: 2011 gti
heres a stage 2 log 3rd gear pull.
Old 03-26-2016, 03:57 PM   #808
Antimatter
Rally Car Newbie
Drives: 2013 GTI
But Cobb's tune is accounting for their own intake which has a custom MAF location and hasn't been tested with the OEM location.
Antimatter is offline   Reply With Quote
Old 03-26-2016, 04:19 PM   #809
thebestdj07
Drives: 2011 gti
there's your test in the log above. seems to run fine.
Old 03-26-2016, 05:48 PM   #810
CarniifeX
Formula 3000 Champion
CarniifeX's Avatar
Drives: '14 CW GTI
Hmmmm. Getting a P2177 and P0420 on the COBB Stage 2 with the COBB intake. Ran a log on my home from the EURO16 show. Mostly freeway. I have no idea what to look for. Could it be because of the MAF position on the intake? Piping is tight so no chance of a vacuum leak anywhere.
Here's a link to my log.
https://www.icloud.com/numbers/000WA...B4A#datalog1_2
'14 Wolfsburg GTI CW 4-Door | BUILD THREAD
CarniifeX is offline   Reply With Quote
Old 03-26-2016, 05:52 PM   #811
spenny02
spenny02's Avatar
Drives: 2011 VW GTI MKVI
What downpipe are you using?
spenny02 is offline   Reply With Quote
Old 03-26-2016, 06:00 PM   #812
CarniifeX
CarniifeX's Avatar
Drives: '14 CW GTI
Unitronic turbo-back
Tags
cobb, tuning, will it fit my honda?
