SELA_MK6GTI
Gtx3071r!!! Do it
I'm still k03 lol I was thinking a k04 or f23t for more power
Gtx3071r!!! Do it
Both are good options for power, I do believe the ko4 has more support and reliability, f23t I think need a custom dyno tune
what kind of numbers have you've seen from other K04 cars?
Mustang dyno + altitude = low numbers.
Your car is prolly making 320 whp on a dynojet at sea level
Mind me to never dyno outside of Florida lol
Your numbers actually look good. You cannot direct compare what other folks are posting in terms of dyno numbers, its not meaningful.
You are running on what appears to be a Mustang Dyno (also called the heartbreaker) that typically reads significantly lower than almost all dynos. Probably a difference of 7%
You are over a mile up, frankly there is just a lot less oxygen per cubic foot, a lot less than folks down at sealevel. That is good for about a 17% power loss.
You don't have a DSG tune so the operator can't push the pedal to the floor, he has to carefully feather it without triggering a gear kick-down, resulting in sometimes less than WOT. Not sure what percent here but it will be some.
Isn't there a way to prevent the transmission from kicking down? I think it was holding the paddle down? I forgot lol
Yeah there's a button under the pedal that tells it to down shift... just gotta go WOT lightly, don't mash the pedal.
It's the opposite... Gotta avoid hitting that button... The button causes the down shiftI tried holding the button down and it didn't work, Once I hit 4300RPM to 4500RPM i was able to go WOT without kickdown.
Hold on a second guys. I'm at 7400ft (JHB South Africa) and my Stage 2+ Unitronic made 325hp and 535nm. So there's not getting around it, 250hp for a K04 is very low.
