Foam Spare Tire Placeholder
steemax
I'd like to get rid of my spare tire but I've tried this before and it bugged the crap out of me! You couldn't place anything heavier than 1 gallon bottle or it would just collapse into the spare wheel well.
So I had an idea and thought it has to exist! I tried searching quite a bit but came up empty handed. I'm looking for something such as a place holder made of hard foam that drops in place of the spare wheel to hold everything up.
6MTCSG
Banned
even better, take your spare out, drill a hole that will fit the plastic screw in on a 2 by 4 and instead of putting the spare back in and tightening the plastic screw, put the piece of wood and tighten it. It will hold the plastic screw up and that will support the carpet
damagi123
good idea
nvturbo
Instead of a wooden 2x4, use thick styrofoam, glued to the spare tire cover. This will cause no noise and weigh next to nothing.
realcyberbob
The Styrofoam I'm referring to is very strong. They use it as padding on thick, heavy glass.
Does this type have a name? Where can you get it?
realcyberbob
