Old 11-17-2018, 10:43 PM   #1
andrewd
Drives: 13 GTI DSG 09 Rabbit 2.5
Cranks dies then starts fine.
I have a 13 GTI with about 96k miles on the clock. Occasionally after trying to start it with the engine warm it will crank die and then when you try to start it again it runs/starts fine. No warning lights, no other driveability concerns. Anyone encounter this?
I should probably add that I replaced that MAF at 27k and the LPFP and fuel pump control module at 71k.
andrewd is offline   Reply With Quote
Old 11-18-2018, 12:14 AM   #2
speeding_ant
Drives: 2011 Golf GTI
Yeah my '11 does that occasionally. My old Honda K24 did it too. And my old mitsi.
Pretty sure it's normal behaviour (if it's occasional). I was told it may be fuel in the rail vaporising due to heat, makes for a tricky start occasionally.
speeding_ant is offline   Reply With Quote
Old 11-18-2018, 02:09 AM   #3
Carlosfandango
FIA GT Champion
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT - 2016 MK7 GTi DSG
Itís low fuel pressure caused by a failing pressure regulator in the fuel filter, replace the fuel filter near the fuel tank.
Old 11-18-2018, 04:13 AM   #4
speeding_ant
Sure, if that hasn't been done (they usually last 60,000kms). I've had mine done within 10,000kms and my car still fails to start every now again when it's warm. I'm talking once or twice a month though.
Old 11-18-2018, 09:41 AM   #5
HYDE16
Formula 2 Driver
HYDE16's Avatar
Drives: 2011 MK6
Are you Kessy?
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 11-18-2018, 08:43 PM   #6
HYDE16
Formula 2 Driver
HYDE16's Avatar
Drives: 2011 MK6
If anyone is experiencing this issue and is KESSY, the issue lies in your button. Remove the button, carefully disassemble and clean the metal contact points. I bet this is it.
Follow this DIY: http://forums.tdiclub.com/showthread.php?t=430031
YouTube: HYDE16
Old 11-18-2018, 10:04 PM   #7
andrewd
I am not kessy. I guess I will start by doing a fuel filter and go from there. The filter is original and it wouldn’t hurt replacing it.
Old 11-19-2018, 01:47 PM   #8
Carlosfandango
FIA GT Champion
I am not kessy. I guess I will start by doing a fuel filter and go from there. The filter is original and it wouldnít hurt replacing it.
Mine had this issue at 98000miles and a new filter fixed it.
