Old 02-14-2018, 06:36 PM   #561
GroceryGTIer
Rally Car Champion
Drives: 2013 black Wolfsburg
Does anyone lube the blue seals before putting the manifold back on? With what if so?
Also, does everyone put their manifold bracket back on? Thing sucks
GroceryGTIer is offline   Reply With Quote
Old 02-14-2018, 06:43 PM   #562
Ronnie_B
Rally Car Champion
Drives: 2013 GTI 4DR Wolfsburg 6MT
Lube the blue injector seals with silicone free motor oil. Obviously do not lube the white Teflon seals. The manifold bracket is the trickiest part of the job. I installed it after the manifold was in place, given that seating the injectors is the highest priority. It's much easier with the TB removed.
APR Stage 2 v2.4 93 tune, APR Cast Downpipe, Unitronic IC, DIY RSR Clutch, Peloquin LSD, iABED RMS, Carbonio Intake, Diesel Geek Sigma 6, DG springs, Koni Yellows, SuperPro ALK / RCA ball joints/ end links, H&R 26mm/24mm swaybars, ECS Subframe collar kit, G-LOC GS-1 / R12 Pads, Stoptech Rotors, TS Brake bushing kit and hatch brace, Castrol SRF fluid, Yokohama AD08R on Motegi MR133 17x8.5 (Track) Build Thread
Ronnie_B is offline   Reply With Quote
Old 02-14-2018, 06:53 PM   #563
GroceryGTIer
Rally Car Champion
I put the white (teflon) seals on by hand and used a zip tie to tighten them, but I wasn't sure about which lubricant to use on the blue seals, obviously I don't want an issue with them.
Old 02-14-2018, 06:58 PM   #564
GroceryGTIer
Rally Car Champion
https://youtu.be/WUfVeO2SJUs
Old 02-15-2018, 12:51 AM   #565
mikedesamero83
Newbie
Drives: 2011 Red GTI
I was throwing a cylinder 3 misfire. I decided to try the cheaper fix: CRC GDI Intake Valve Cleaner. I have 80k miles.
1 month later: check engine light hasn't come back on, acceleration seems smoother, no rough idle.
Good fix for the price. I might spray another bottle after another 1K miles.
mikedesamero83 is offline   Reply With Quote
Old 02-15-2018, 12:25 PM   #566
GroceryGTIer
Rally Car Champion
It's very good for dissolving carbon, but to do really breaking down, 30 minutes of it sitting on a valve will do wonders, simply sweeping passed it won't do a whole lot. After cleaning mine manually the first time, I literally let the valves sit over 24 hours in b12 chemtool and even then, they had to be scrapped and cleaned with effort.
Old 02-15-2018, 12:36 PM   #567
wmssbr10
Drives: 2010 GTI
I had 80k no CEL's and no rough idle but was going K04 so did cleaning and tensioner. The valves were caked and gummy with carbon. A lot of 2+2 gum cutter and scraping was necessary to clean them up.
wmssbr10 is offline   Reply With Quote
Old 02-16-2018, 05:51 PM   #568
GroceryGTIer
Rally Car Champion
If you use that GDI cleaner and let it soak, you hardly have to scrape it, same with b12 chemtool
Old 11-27-2018, 11:03 AM   #569
ben_m
Rally Car Newbie
Drives: Mkvi GTI / MDX
VW Huntington gave me a solid deal, I needed my intake manifold replaced and since they were already tearing into the car it only cost me 1.5hours in labor for the cleaning Not sure how bad it was, car was at 63k mostly local driving.
ben_m is offline   Reply With Quote
Old 02-12-2019, 04:14 AM   #570
bruxwillix
Newbie
Drives:
apologize if this was already mentioned.. long thread.
but is it the general consensus that an induction service at the dealership does nothing? not even a good preventive measure? "pressurized atomizing" they're calling it. basically hooking up to a vacuum line with something similar to but i hope more hi tech then this
https://www.ecstuning.com/b-sur-and-...srrfic903~srr/
thinking of getting 1 of those canisters and filling it with some CRC valve cleaner but did want to start with an induction service at ther dealer. unless my fellow enthusiasts advise otherwise....
bruxwillix is offline   Reply With Quote
Old 02-12-2019, 06:50 AM   #571
realcyberbob
realcyberbob's Avatar
Drives: 2011 GTI
Send a message via AIM to realcyberbob
It may do something to keep valves clean once they've been cleaned, but to actually clean them you have to scrape or walnut blast.
2011 CW GTI 6-Speed: APR Stage II, APR Carbonio Intake, Clutch Masters FX350 Clutch Kit, 42nd Draft Designs Downpipe, Magnaflow Catback Exhaust, Forge Twintercooler, BFG DV+, Dieselgeek Short Shifter, ECS Dogbone Mount Insert, StopTech Pads & Slotted Rotors, Tyrolsport Brake Stiffening Kit, Golf R LED Tail Lights, CiM Vent Boost Gauge, RNS-510 Navigation, Uber-Stealth Box & 10" Pioneer Sub, Alpine MRP-M500 Amp, 25th Ann. GTI Golfball Shift Knob, Modshack Low Profile Engine Bay Trim, Hankook V12
realcyberbob is offline   Reply With Quote
