Old 07-23-2018, 08:03 AM   #127
brobst
Formula 5000 Champion
brobst's Avatar
Drives: CSG mk6 6MT
Afr you just making sure you arent lean in pulls. Number should be smaller than 14.7 when wot.
Fuel trims you are looking for ~1.0. It shows if car has to add fuel or subtract fuel from requested. Greater than 1 I believe its trying to add, less than 1 take away fuel. More just shows how your car learns
Old 07-23-2018, 05:05 PM   #128
cgj_mk666
Drives: 2011 GTI 6MT.
Thank you. I appreciate it
Cobb AP. Stratified Tuned. Godspeed FMIC. H&R Sport Springs. Autotech/Sachs struts. ECS Strut mounts. 034 Track Density mounts. S3 control arm bushings. H&R/Eibach sways, EBC rotors. Custom Intake and Turbo-back. Continental ExtremeContact Sports
cgj_mk666 is offline   Reply With Quote
Old 12-13-2018, 11:50 AM   #129
Tony48
FIA GT Newbie
Tony48's Avatar
Drives: 2011 GTI / K04 / 6MT
Trying to figure out launch control but can't get it to work. I have read the info on the Cobb website (here and here).
Flashed to the most up to date (v106) OTS Stage 2 / stock MAF / 93oct tune and following these steps for 6MT:
  • Depress and hold the clutch pedal to 100%
  • Move the shifter to 1st gear
  • Depress and hold the gas pedal to 100%
  • Once the rev limit has been reached, release the clutch pedal
Rev limiter doesn't kick in and the engine revs to red line. What am I doing wrong? Can't get burnout mode to hold RPM either.
EDIT: Figured it out. I wasn't putting the pedal to WOT quickly enough. You can't ease into the throttle, you have to go WOT before the RPM's get to your launch control limit.
| 2011 GTI - P&P K04 - Stratified ProTune | Build Thread| Timing Chain Replacement Tips | DIY RSR Clutch & RMS Replacement Tips|
Old 02-08-2019, 10:41 AM   #130
rawag77
Rally Car Newbie
Drives: 2013 GTI Autobahn
Are you guys still experiencing the Accessport randomly detecting the engine is off and rebooting even when the car is running/moving? I know this has to do with the Auto On/Off feature and it was recommended by Cobb to turn that off, but what's the fun in that. Just checking to see if there was ever a fix. As far as I know, I have the latest firmware, but it still happens to me on a daily basis. 3 times on my 30 minute commute home yesterday.
rawag77 is offline   Reply With Quote
Old 02-08-2019, 07:25 PM   #131
theclutch
Rally Car Newbie
theclutch's Avatar
Drives: Mk6
This happens to me also. But it does start back up. The only thing I "lose" is whatever was the max value on the gauges when it went out - which is no big deal.
theclutch is offline   Reply With Quote
Old 02-12-2019, 12:59 PM   #132
kiyoshi147
Touring Car Newbie
kiyoshi147's Avatar
Drives: 2013 GTI DSG 4 Door w/Nav
I had this issue with when the Auto On/Off was enabled. It happened far less often with the Auto On/Off disabled. Sent it back to Cobb, they looked at it and sent me a new one.
Continued to run with Auto On/Off disabled for a while with few reboot issues, and recently switched back to Auto On/Off enabled and haven't noticed a real increase in the frequency of the issue.
I drive at minimum an hour each way to work, so I have gotten a reasonably good sampling time. Never got a firm answer from Cobb as to why it was doing this though. They couldn't find a reason, hence just sending me a new accessport.
In other news, still waiting for the max temp value for Oil (Sump) and Coolant (and probably a few other monitors) to be brought down from the 3000 or whatever value it switched to on a firmware update a while ago. hard to really see the difference on the bar graph between 50 and 220 when the graph scale is from -300 to 3000.
kiyoshi147 is offline   Reply With Quote
Old 07-14-2019, 09:55 PM   #133
speeding_ant
Drives: 2011 Golf GTI
Looks like Cobb have updated the AP to support a few more world market Mk6 GTI ECUs. Also, they've said they are still working on a DSG tune for our cars... cross fingers...
speeding_ant is offline   Reply With Quote
Tags
accessport, accesstuner, cobb, cobb tuning, tune
