Hey everyone, I’ve searched for countless hours on possible solutions for this CEL code but I need some advice.
2013 gti, awe turboback exhaust, unitronic stage 2, unitronic intake, r8 coilpacks, new spark plugs, new pcv, 117000km
I’ve have had zero issues up until a week ago. I had surging rpms and replaced my pcv valve because I figured the code was because of that. After replacing the pcv, the surging stopped, I cleared the code and it reappeared after a day.
On idle my vacuum is reading 10-12psi vacuum, boost is ranging between 18-20psi which is what I’ve always been having. I do not have vagcom (I’ve been reading it using the dash command app).
Under WOT, I am hearing a new noise around the front passenger side. Almost sounds like the turbo is shuttering and it sounds a bit louder than usual (yes it sounds nicer but it’s not normal). I thought it was a loose downpipe leak around the first o2 sensor but I took it to the mechanic and there was no leak at all.
My mileage has reduced ever since I got this code. (Usually get around 600km per tank) but now I’m barely hitting 500km and I do not have a heavy foot.
My next guess would be the o2 sensor that’s right after the turbo on the downpipe but I’m not too sure anymore on what else to look for.
I do not have any other codes, no misfires, no surging rpms, vacuum/boost seems okay...I’m stumped.
My mechanic suggested to replace the o2 sensor on bank 1 because that could possibly be the air fuel ratio sensor? (I don’t know).
Have not done carbon cleaning or throttle body cleaning yet either.
Any help is greatly appreciated!
