Old 08-20-2019, 11:38 AM   #1863
You may have sucked some plastic into the head. Here is a pic of my old manifold, it was missing a huge chunk that I think stayed in the motor until it disintegrated.
Get all mods done pre marriage.
Old 08-20-2019, 01:50 PM   #1864
Blakcard
Blakcard's Avatar
would make sense i guess.. .if i recall correctly.. it was within a week or so after i did the chains/guides when flap went and I got the code. It's my third manifold so I'm sure some of that Shite is in there somewhere.
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old 08-20-2019, 04:52 PM   #1865
KFahey
KFahey's Avatar
Drives: 2011 MK6 GTI-MT
Originally Posted by GTIguy30 View Post
Received my check from the timing chain settlement!!!
Got mine today too!
APR K04 V3.1 | Unitronic CAI | CTS TBE | NewSouth Boost Gauge | R8 Coils | RSR Clutch Kit | OEM LED Tails | VWR Springs | KONI Yellow Front Struts | GFB DV+ | CTS Intercooler | 034 Street Mounts
KFahey is offline   Reply With Quote
Old 08-20-2019, 05:46 PM   #1866
tkelly0727
Drives: 2010 mk6 gti DSG
Out of curiosity, i was watching humblemechanic new video about using VCDS. he mentioned something that people overlook on there after they replaced their timing chain which is inside basic setting " Timing chain elongation: reset after chain replacement"
have any of you guys did this procedure? I had mine replaced by the dealer not sure if this was done or not.
tkelly0727 is offline   Reply With Quote
Old 08-20-2019, 05:54 PM   #1867
BudgetPhoenix
Drives: 09 GLI
Never heard of it, never heard of anyone doing this on a gen 1 tsi. In the video it looks like hes hooked up to Gen 3 MQB TSI engine. As far as I know nothing like this is required after doing the chain and ive done the chain on mine.
Old 08-20-2019, 06:11 PM   #1868
tkelly0727
Yes he has a mk7.5 R now. thanks for clearing that up! i actually dont own VCDS but im looking to pick one up and retire the OBD11 .
Old 08-23-2019, 05:18 PM   #1869
SC_MK6
Drives: 2012 csg gti autobahn
Hey what's yalls thoughts on the ultimate timing chain kit assembled by ecs? Its half the price of the vw/Audi kit. They use mostly Bremmen brand parts in that kit. Is that a reliable brand? I dont know anything about them. Who makes the chains and tensioners for VW?
Sent from my SM-N950U using Tapatalk
SC_MK6 is offline   Reply With Quote
Old 08-23-2019, 07:23 PM   #1870
BudgetPhoenix
Drives: 09 GLI
Bremmen parts are rebranded aftermarket Chinese stuff sold by ECS. That's why they are so cheap. I would highly recommend getting the OEM chain. tensioner and guides. People have had aftermarket chinese tensioners and cam bridge failures causing a lot of damage...
Old 08-27-2019, 12:02 PM   #1871
I think some Bremmen parts are made in Germany. I can't say all of them.
I pieced my kit together, new OEM tensioner, new lower cover, upper gasket, Febi chain. Reused hardware with blue loctite, except the crank bolt that was new. If you're careful and cheap, you could reuse everything including the cover and gaskets. My rails were in good shape so I reused them, except the top one I broke when removing.
Whatever you do, don't buy the kit from partsgeek. That is straight China garbage.
Old 08-31-2019, 11:21 AM   #1872
foxbyt3
The timing chain rattle sound just started on my 2012 GTI yesterday. I've been reading through this thread and others like it but one thing I haven't found an answer for is, is it safe to drive the car?
I'm going to contact my shop ASAP and get the car in immediately, but in the mean time I want to be sure i'm okay to drive per usual.
foxbyt3 is offline   Reply With Quote
Old 08-31-2019, 11:43 AM   #1873
BudgetPhoenix
Drives: 09 GLI
Yeah I pieced mine together as well for a good price, OEM tensioner, OEM chain, new lower cover, new guides (though old weren't bad), new gaskets and new bolts.
Old 08-31-2019, 01:46 PM   #1874
GeorgiaBII
GeorgiaBII's Avatar
Drives: 2011 APR Stage 2 DSG Autobahn
Not safe.
GeorgiaBII is offline   Reply With Quote
Old 08-31-2019, 06:54 PM   #1875
SC_MK6
Yea I talked to someone at ECS and he told me to go with the Febi branded parts. He said Febi are German, Bremmen are not.
Old 09-10-2019, 09:03 PM   #1876
2012TP
2012TP's Avatar
Drives: Slow
Car went in today for the full job. Vagcom block 093 was reading -4.84, so i guess itís overdue. 2012 with ~114k
=====(\x/)=====
2012TP is offline   Reply With Quote
