Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > UNITED KINGDOM
Old 03-12-2018, 04:34 PM   #29
Carlosfandango
FIA GT Champion
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT - 2016 MK7 GTi DSG
I’m not really sure why you’ve already come to the conclusion it’s the injectors (my reply above was on the assumption you had changed the filter) when you hadn’t fitted the filter until today, it may well not be the filter (I think it is though) but you should have fitted a new one before trying anything else as it’s a major culprit when you have your symptoms, your plug looking a little sooty and the fuel smell from the exhaust are both symptoms of low fuel pressure as are your other symptoms, although these symptoms can point to other things as well i think that in your case these combined point to it being a faulty pressure regulator in the old filter.
Old 03-12-2018, 06:54 PM   #30
VW6
Drives: MK6 1.4 TSI
Originally Posted by Carlosfandango View Post
If your original was 6.6 and you then put in a 6.4 it would not be ok but I’m not sure the other way around? I think it’s ok but I’ll need to check, what is the car behaving like with the new filter fitted? Have you cleared the fault codes? Do they come back?
Original was 6.4Bar it had done 60K miles, i have had the car since 30K miles and i have not had it changed and from what i can see the previous owner didn't change it either so it was due i believe.
The new one is 6.6Bar the car started straight away and i done a test drive with no problems, the car was a little shaky still on idle but no fault codes at the minute but i have not really drove it, i'm going to cold start it tomorrow morning and give it a good drive on the country roads near me.
So that's spark plugs, coils and fuel filter if it has not resolved my problem it should be the injectors.
VW6 is offline   Reply With Quote
Old 03-12-2018, 06:57 PM   #31
VW6
Drives: MK6 1.4 TSI
Sorry man, i agree.
Lets see what tomorrow brings, i tend to always expect the worst case.
Along with people telling me its the injectors and when i mentioned the fuel filter they said if it was then my misfire would be on all cylinders and not just the one so that put doubt into my mind but i hope you are right.
My code reader is sh*t as well and has sometimes not shown me a fault code when i have the check engine light and EPC light lit up...
Old 03-13-2018, 02:10 AM   #32
Carlosfandango
FIA GT Champion
Originally Posted by VW6 View Post
Sorry man, i agree.
Yeah the single cylinder misfire doesn’t really fit with it being the filter but as you say your code reader isn’t reading correctly then maybe it’s missing on all cylinders hence the other symptoms! Or missing worse on one cylinder somehow!
Old 03-13-2018, 04:07 AM   #33
VW6
Drives: MK6 1.4 TSI
Well car is not starting again...
Starts but cuts out straight away and can hear like a weird whistle noise as it turns off but that could just be me and my ears i will have to record it
Old 03-13-2018, 05:02 AM   #34
Carlosfandango
FIA GT Champion
The in tank fuel pump is another possibility but if you can hear it prime (it won’t prime every time) then it’s probably ok.
Old 03-13-2018, 05:04 AM   #35
Carlosfandango
FIA GT Champion
Have you checked all of the previously mentioned causes of the P0302 code?
You need to troubleshoot properly not just guess,
Possible causes of P0302
Faulty spark plug #2
Clogged or faulty fuel injector #2
Faulty ignition coil #2
Fuel injector #2 harness is open or shorted
Fuel injector #2 circuit poor electrical connection
Ignition coil #2 harness is open or shorted
Ignition coil #2 circuit poor electrical connection
Insufficient cylinder #2 compression
Incorrect fuel pressure
Intake air leak
Old 03-13-2018, 05:11 AM   #36
VW6
Drives: MK6 1.4 TSI
https://www.youtube.com/watch?v=sQgp...ature=youtu.be
Car will start after a few trys but will do this. EPC (throttlebody?) and Check engine light is lit no throttle response, just cuts out.
Then if you try a few more times it will then start with no lights on ect
Old 03-13-2018, 05:16 AM   #37
Carlosfandango
FIA GT Champion
You would probably be better asking about this in the relevant section of the main forum as other members will have more knowledge of the issue and can likely help better than I can, the regional UK forum is not really visited by many and I only saw your post as I was un knowingly subscribed to it.
Old 03-13-2018, 05:23 AM   #38
VW6
Drives: MK6 1.4 TSI
Will do which section? GTI 2.0T Engine / Drivetrain / Exhaust / Tunes?
Old 03-13-2018, 05:26 AM   #39
Carlosfandango
FIA GT Champion
That or general discussions but as your not a 2.0tsi I’m not sure.
Old 03-13-2018, 05:26 AM   #40
VW6
Drives: MK6 1.4 TSI
True ill post in general
Old 03-13-2018, 06:47 AM   #41
Carlosfandango
FIA GT Champion
You may have to wait until later for any responses in your new post as the bulk of members on here are North American, I don’t think they had the 1.4 tsi over there but the symptoms should be universal I would think, a lot of the guys on the forums are very knowledgeable about the VW brand and will guide you in the right direction I’m sure.
Old 03-22-2018, 04:31 PM   #42
VW6
Drives: MK6 1.4 TSI
For anybody interested it was my fuel pump
