Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > UNITED KINGDOM
Old 03-05-2018, 06:09 PM   #15
Carlosfandango
Carlosfandango's Avatar
Obviously it would be wise to swap the plug around to check if the misfire moves with it,
Possible causes of P0302
Faulty spark plug #2
Clogged or faulty fuel injector #2
Faulty ignition coil #2
Fuel injector #2 harness is open or shorted
Fuel injector #2 circuit poor electrical connection
Ignition coil #2 harness is open or shorted
Ignition coil #2 circuit poor electrical connection
Insufficient cylinder #2 compression
Incorrect fuel pressure
Intake air leak
Old 03-06-2018, 11:05 AM   #16
VW6
Drives: MK6 1.4 TSI
Intake air leak
I no i should have done the fuel filter already!! haha i will get on to it.
Thanks for your help!
Can you tell me about this noise from my exhaust
https://www.youtube.com/watch?v=iXxL_tBblJc
Also what is this hole underneath my car?
https://imgur.com/a/T38aD
VW6 is offline   Reply With Quote
Old 03-06-2018, 03:12 PM   #17
Carlosfandango
Thatís part of the rear subframe I think? (A little hard to tell) , the hole is normal itís in all of them, a drain I believe!
Old 03-06-2018, 03:20 PM   #18
Carlosfandango
1.4 TSI - Engine/Start up problems.
The noise sounds like exhaust baffles, tap the silencers with a closed fist or a rubber mallet to see if you can make the noise, I had that noise on my MK1 fiesta XR2 many years ago, not a good idea as it will restrict flow but all I did was just hit the silencer with a mallet until I trapped/jammed them (I was 17 and didnít care), but as said not a smart move so if you find it is the baffles youíll have to replace the exhaust or live with it!
Could also be the cat or something else such as a blowing exhaust but hard to tell from the other end of an internet connection!
Old 03-11-2018, 11:18 AM   #19
VW6
Drives: MK6 1.4 TSI
Not solved.
Exhaust is smoking/ making noises
Car will misfire on idle once its warmed up
Old 03-11-2018, 01:51 PM   #20
Carlosfandango
Whatís not solved? Exhaust or the filter?
Old 03-11-2018, 01:53 PM   #21
Carlosfandango
Have you swapped the plug and coil packs around to see if the problem moves to a different cylinder?
EDIT: just remembered you already swapped the coils!
Old 03-12-2018, 05:49 AM   #22
VW6
Drives: MK6 1.4 TSI
Both
Got to be fuel injectors?
Rough idle/starting ONLY - never when driving, has no loss of power
MPG has dropped
Sometimes when trying to start EPC and CEL lights up, has no throttle response at all.. you can't rev it.
Exhaust smoking and it smells of fuel
Exhaust rattle/noise
I no i should have took it to a garage by now but ive been busy.
Old 03-12-2018, 05:52 AM   #23
Carlosfandango
Both
MPG has dropped
I no i should have took it to a garage by now but i just been busy.
Yeah that does sound like an injector issue or possibly the wiring to the injector! As said though itís hard to diagnose from the end of an internet connection!
Old 03-12-2018, 05:55 AM   #24
VW6
Drives: MK6 1.4 TSI
How much am i looking at if it was the fuel injectors? ££
Old 03-12-2018, 06:01 AM   #25
Carlosfandango
I donít know the cost as never needed to have it done but the intake will need to come off to get to them so probably around two hours to change them plus the parts cost, did you change the filter already??
Old 03-12-2018, 01:17 PM   #26
VW6
Drives: MK6 1.4 TSI
https://imgur.com/a/DQSd5 - Old filter 6.4BAR, the one i put on was 6.6BAR will that be ok?
Yes only today though should i let it run a little? Not tried a cold start yet.
Old 03-12-2018, 04:01 PM   #27
Carlosfandango
If your original was 6.6 and you then put in a 6.4 it would not be ok but Iím not sure the other way around? I think itís ok but Iíll need to check, what is the car behaving like with the new filter fitted? Have you cleared the fault codes? Do they come back?
Old 03-12-2018, 04:17 PM   #28
Carlosfandango
Using the 6.6 bar as apposed to the 6.4 bar appears to be fine (at least on the GTi anyway) so you should be ok.
