Old 01-14-2019, 12:00 PM   #44353
DASVDUB
Formula 2 Driver
DASVDUB's Avatar
Originally Posted by franco516 View Post
the PCV came with a new gasket.
Fresh spark plugs and coil packs? Any CELís? Bad tank of gas?
2dr 2011 Candy White GTI|APR Stage 2|Godspeed catless dp|custom straight pipe catback|Carbonio Stage 1 & 2|Forge Diverter Valve|H&R Super Sports|Koni Orange Struts & Shocks|R8 Coils|NGK BKR7EIX Plugs|Soundaktor delete|20% tint|
Old 01-14-2019, 12:03 PM   #44354
uglybastard
Formula 3000 Champion
uglybastard's Avatar
Drives: VW Mk6 GTI 3 pedal in CSG; Jeep WJ
my initial thought is that this might not be seated entirely - as the engine heats up the gasket expands into place.
other thought is what was being alluded to before, with the old rebreather hose that connects just above the turbo at the intake pipe. if mis-seated there, you'd see weird starts. work rechecking that seating and as a consequence, confirming all the hose connections to the PCV.
also normal RPM at idle after warmup phase for me on stock tune was ~ 1000rpm. tunes you could see as low as 700rpm, varies by tuner.
..246.............. Insta
Old 01-14-2019, 12:07 PM   #44355
franco516
FIA GT Newbie
franco516's Avatar
Drives: gti
plugs should be good since i changed them when i went k04 over the summer, no issues since then so i doubt it. bad gas? maybe..
i will look into that intake hose connection later, thanks for the advice.
IG - @francotirador91
franco516 is offline   Reply With Quote
Old 01-14-2019, 04:10 PM   #44356
franco516
FIA GT Newbie
franco516's Avatar
Drives: gti
hoses seemed to be ok but i bought two new hoses just incase
Old 01-14-2019, 10:20 PM   #44357
DASVDUB
Formula 2 Driver
DASVDUB's Avatar
When was the last time you filled up?
Old 01-15-2019, 01:39 PM   #44358
franco516
FIA GT Newbie
franco516's Avatar
Drives: gti
before installing the new pcv. its deff not the gas.
Old 01-15-2019, 02:53 PM   #44359
Blakcard
FIA GT Champion
Blakcard's Avatar
is there even a way to check the diaphragm on the new PCV before you installed? can you check it now? make sure the spring etc is seated correctly?
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old 01-15-2019, 04:57 PM   #44360
franco516
FIA GT Newbie
franco516's Avatar
Drives: gti
id have to remove it. i had the dude at the shop install it. i bought new hoses hoping thats the issue, once i replace those and the issue persists ill reinstall the entire thing.
Old 01-15-2019, 07:07 PM   #44361
DASVDUB
Formula 2 Driver
DASVDUB's Avatar
If you re install. Ensure you remove the oil thatís under said PCV before re installing
Old 01-16-2019, 03:25 PM   #44362
Allchokedup
Touring Car Newbie
Drives: 2011 ko4
Burnouts in the rain...
Allchokedup is offline   Reply With Quote
Old 01-18-2019, 01:05 PM   #44363
franco516
FIA GT Newbie
franco516's Avatar
Drives: gti
any of u guys have michelin pilot sport a/s ? any thoughts?
Old 01-18-2019, 02:44 PM   #44364
pdan
Rally Car Newbie
pdan's Avatar
Drives: 2009 VW Jetta TDI (sold), 2013 GTI
Iíve got pilot sports a/s 3+ currently. Very happy with them as far as all seasons. Theyíre definitely starting to wear down after about 25K miles or so, will probably replace with something very similar. Still not in a position where I can run a dedicated summer tire yet.
CW 2dr 6MT-Stratified Tuned-Unitronic Intake-Southbend Stage 2 Daily-R8 Coils-NGK Plugs-ECS Tuning 3in Catted Downpipe-Neuspeed Catback-ECS Tuning Dogbone Mount-Unibrace UB-GFB DV-OEM LED Dark Cherry Tails
pdan is offline   Reply With Quote
Old 01-18-2019, 03:58 PM   #44365
franco516
FIA GT Newbie
franco516's Avatar
Drives: gti
they grip well in dry/summer conditions?
Old 01-18-2019, 06:36 PM   #44366
torga
Touring Car Champion
torga's Avatar
Drives: '11 GTI - 6MT - 2dr
Out with the old, in with the new. Installed my Beluga Racing catback today. Not as big of a difference as I expected since my stock exhaust was de-resonated, but the exhaust note is definitely cleaner and sounds a bit more aggressive at WOT. Very classy/understated when not on the accelerator.
torga is offline   Reply With Quote
Tags
#assman, #saveboostedvw11, "yeah" -marshawn lynch, brunkelgotback, circlejerk thread, dat forum doe, dont care it got driven, dont quote pics people, dsgsr4women, dubpl8 1-900-suk-ndik, dubpl8 ate his dads ass, dubpl8 likes shrimping, fukyours2k, i pooped today, i'm an excellent driver, ihadsexwithmygastank, my body is ready, no one cares tiggy, nobodycares u washedit, purple helmet warrior, really nbdy crs u wshd it, sexybrunkel, srs ndy crs u washed it, vandorin was here, who's dubpl8?
