Old 06-11-2019, 12:02 PM   #225
zef
Originally Posted by GoLfUnV View Post
Great build, love the color! However i was curious as to why did you take off passat spindles?
Great question. Unfortunately, my Brembo BBK bolts to the outside of the spindle. The "ears" of the Passat spindles are thicker, so the brackets are pushed too far inside the wheel well for the calipers to bolt up. This wasn't an issue with my prior brake setup because they bolted to the inside of the spindle, and all I had to do was run longer caliper bolts.
Both with the Passat spindle and with the OE steel spindle, my superpro ball joints had no problem clearing the brembo rotors (355x32); though the clearance is pretty tight. I'll have to DEI foil wrap the boots just to be safe.
KO4 Track Car - No Expense Spared. Build Thread
Crackle tunes are for ricers, change my mind.
Old 06-11-2019, 12:03 PM   #226
jay745
jay745's Avatar
DEI wrapping the ball joints is good practice anyways.
MK6 K04 GTI Build Thread
improvise. adapt. overcome
Old 06-11-2019, 02:31 PM   #227
GoLfUnV
Drives: 2010 Gti CW
Did you think about machining the "ears," or was the "offset" too big?
GoLfUnV is offline   Reply With Quote
Old 06-11-2019, 02:56 PM   #228
zef
It absolutely crossed my mind, but this was discovered earlier this week with less than a week to go before my track day at Thompson. Due to time constraints I decided it was better to go back to steel.
It was off by a fairly significant amount however, so I am not sure that would be safe. What I would end up having to do most likely is building custom brackets.
If the steel spindles do end up failing then I'll either have to change my brake setup again or figure out at way to make it work.
Agreed, I'm going to wrap the ABS sensors too just to be safe.
Old 06-11-2019, 03:24 PM   #229
GoLfUnV
Drives: 2010 Gti CW
Thanks! glad i found your build thread... I have set of boxster brembo calipers, waiting on rebuild, before i install on my mk5. I was contemplating passat spindles, for un-sprung weight reduction, but looks like i may have to do some more research.
Old 06-11-2019, 03:29 PM   #230
jay745
jay745's Avatar
Zef did you by chance weigh the spindles to see what the weight savings actually is? I've considered doing that for years (last part of the unsprung weight items that I haven't converted over) but the fitment with brakes has kept me away.
Old 06-11-2019, 11:06 PM   #231
zef
Those I am pretty sure bolt to the inside of the spindle so you should be okay, but definitely double check.
I didn't, but someone else did: https://www.golfmk6.com/forums/showt...t=47369&page=2
About ~3lb difference per spindle.
Old 06-17-2019, 11:13 PM   #232
zef
Today was a final big push to get the car ready for tomorrow.
- New APR Intake filter
- Cleaned MAF
- Changed oil with fresh 300v
- Wrapped ABS sensors/ball joints in DEI foil (clearance between superpro ball joint and rotor is literally 1mm, maybe 2)
- Test fitted 8mm APR spacers with extended tuner lug bolts (35mm bolts) on front to ensure proper clearance
- Fresh coat of glass sealant in anticipation of the crummy weather
- And finally fully packed the car with everything (tools and all)
Here's what the fronts look like with 8mm spacers. Originally 5mm cleared the shock, but only barely. It was decided 10mm would be too much, so I went with 8mm, and it's totally spot on.
Old 06-19-2019, 01:23 PM   #233
zef
First track day was a huge success. It was pouring ass rain for the first 2 sessions which made for lots of fun. It dried up for the last 2 sessions and I got some quality runs in. Oil temps got pretty warm (~265F), but coolant temps seemed pretty stable. "brake fluid-owners manual" came on a few times pulling into the pits, but I am assuming that's my car complaining about hot brake fluid.
Oh, and I also cracked my downpipe pretty good (again!), so I have an APR downpipe going in to replace my Cobb. Done with that company forever.
Photos/Video coming soon...
Old 06-19-2019, 01:31 PM   #234
DASVDUB
Formula 2 Champion
DASVDUB's Avatar
Yeah Iíve heard complaints numerous times on Cobb exhausts. Subi platform has issues with them too.
Did you check your reservoir when that popped up? What fluid you running?
2dr 2011 Candy White GTI|APR Stage 2|Godspeed catless dp|custom straight pipe catback|Carbonio Stage 1 & 2|Forge Diverter Valve|H&R Super Sports|Koni Orange Struts & Shocks|R8 Coils|NGK BKR7EIX Plugs|Soundaktor delete|20% tint|
Old 06-19-2019, 01:46 PM   #235
zef
Reservoir was full, level didn't budge.
3 day old Castrol SRF fluid.
Old 06-19-2019, 05:43 PM   #236
theclutch
theclutch's Avatar
Drives: Mk6
Where? What track? Per chance, did you log EGT?
theclutch is offline   Reply With Quote
Old 06-19-2019, 06:15 PM   #237
APRMK6GTi
APRMK6GTi's Avatar
new APR downpipe is pretty well constructed, my 42dd downpipe cracked also, hopefully APR one will last
2012 CSG GTI 6SPD | APR Tuned | AWE K04 | APR Carbonio | IE FDS IC | APR DP | Magnaflow | Neuspeed TOP/ACP | GFB DV+ | DG S6 | Fluidampr| OEM MSB | Verdict SBB | HST RSR | ECS Bleeder Block | SuperPro LCA/ALK | 034 Mounts | AST/GC | OZ | ST40| Whiteline 24MM F&R | Tyrolsport | Unibrace XB/UB/RB | EuroSport LB | Euro OEM LED | OEM Aero | P3 | VERUS |
Nor Cal VW Drivers Club
Old 06-19-2019, 10:15 PM   #238
zef
This was at Thompson. I didn't log EGT, but if I had to guess it was pretty damn hot (1800F+). To be fair this was the re-welded downpipe I've had for over a year so I knew I was on somewhat borrowed time.
I have the old style downpipe, but I've heard good things.
