Old 06-18-2019, 02:04 AM   #7057
parteo
Drives: SCIROCCO 2.0TSI big turbo
Originally Posted by parteo View Post
inally i finished my set up
gtx2976 w/g
ns racing exhaust manifold
hpa intake nanifold
apr intercooler
zzp injectors
hpfp loba(cawb)
tuned by dynodrome
big lpfp(0-400 tune to race)
cp pistons
intergrated rods
exhaust cam shaft reprofile
supertech kit reteiners etc
snow perfomance 60/40 water methanol
dyno plot below
parteo is offline   Reply With Quote
Old 06-18-2019, 02:07 AM   #7058
mostic
mostic's Avatar
Drives: VW
dyno plot below
Nice graph, congratulations.
Old 06-19-2019, 12:48 PM   #7059
A3-Owner
Drives: MK6 GTI/Audi A3
Originally Posted by U-20T View Post
Want an aquamist setup? I'm going to be selling mine shortly. Can do it with my dual tank setup and two FAV valves. Pretty perfect setup for you as you want fuel and cooling.
Thanks U-20T. Not at this time. If I decide to tune for WM, I will hit you up. Just want to get the car 100 percent happy on 91 with this unique setup.
2013 VW GTI
A3-Owner is offline   Reply With Quote
Old 06-19-2019, 12:48 PM   #7060
A3-Owner
dyno plot below
Nice power levels.
Did you tune for Water Methanol or no?
2013 VW GTI
Old 06-19-2019, 11:15 PM   #7061
parteo
Originally Posted by A3-Owner View Post
Nice power levels.
Yes I tune with water methanol in high pressure.
Old 06-21-2019, 09:59 AM   #7062
jettaglx91
Drives: AWD GTI, Touareg, RS3, multiple MK2
always forget about this forum since everything is pretty much social media nowadays.
Got my car running pretty good on straight pump e85(e80) about 25psi but this was definitely beyond the sustainable limit of the hpfp volume. Dropping the ethanol percentage is better. Now just waiting on that big bore pump
2010 GTI(all wheel drive)
UM Tuning
APR 3071 turbo kit
Nostrum HPFP
Nostrum Injectors
TTRS LPFP
IE Rods
Other normal bolt ons
jettaglx91 is offline   Reply With Quote
Old 06-21-2019, 08:10 PM   #7063
A3-Owner
UM Tuning
APR 3071 turbo kit
Nostrum HPFP
Nostrum Injectors
TTRS LPFP
IE Rods
As Borat would say,"Very nice, I like."
Short of the injectors and fueling, we have the same setup. I have a gen 2 GTX versus the gen 1 you have the from the APR kit. Good to know what the HPFP can do on E85.
2013 VW GTI
Old 06-24-2019, 11:13 AM   #7064
jettaglx91
dyno plot below
why is that so insanely laggy? That turbo should be ready to party by 3500rpm
Old 06-24-2019, 11:27 AM   #7065
franco516
franco516's Avatar
Drives: gti
hey guys. Been having an issue since going BT. power cuts out when going into boost, can be in 3rd 4th or 5th. never know when its going to happen, sometime its 1st time hitting boost and sometime its after many WOT runs. Car is failsafing bad and once it cuts power it wont come back on until i restart the car.. thinking its one of the pumps, how does one test for a bad/clogged pump?
IG - @francotirador91
franco516 is online now   Reply With Quote
Old 06-24-2019, 01:23 PM   #7066
Cadubya
“DUBYA” VP COUCH MOD
Cadubya's Avatar
Seems like a big exhaust wheel for that compressor size.
CLICK HERE FOR MY BUILD
Cadubya is online now   Reply With Quote
Old 06-25-2019, 02:42 AM   #7067
parteo
GTX2976R SPECS
Inducer Exducer Trim A/R Inducer Exducer Trim
836041-5004S 836013-0004 58mm 76mm 58 0.60 57mm 54mm 90
Notes: Turbine Kit PN A/R Inlet Outlet Wastegate Divided Trim
Super Core and Turbine Kit Sold Separately 827690-0007 0.86 T25 5-Bolt Wastegated N 90
Old 06-25-2019, 12:25 PM   #7068
jettaglx91
The compressor is big but the exhaust wheel is smaller than mine.
Old 06-25-2019, 12:27 PM   #7069
jettaglx91
GTX2976R SPECS
I wonder if that .86 turbine housing is making that much of a difference? That turbo should have a WAY bigger powerband
Old 06-25-2019, 12:45 PM   #7070
erball
erball's Avatar
Drives: Rolling burnouts
I was gonna chime in on that. I had very similar spool on a gtx3071r on a .86. Switched to the .64 and picked up nearly 1500rpm in spool.
Big Turbo Build Thread.
erball is offline   Reply With Quote
addicted to torture, blow up ur volkswagen, breaking your trans 101, failwheeldrive anonymous, fireball lives!, james'partout
