Did you use an Africa plate or just fully route the PCV to the can (like the ECS kit does)?You'll probably get a lot of different answers. I replaced the breather hoses each time I replaced the pcv. Eventually just got a catch can because I got sick of the pcv's constantly crapping out.
I have an IE can that uses an "africa plate"Did you use an Africa plate or just fully route the PCV to the can (like the ECS kit does)?
What happens if I swap it out and there's a microfracture in one of the tubes I missed or can't see? Would the symptoms persist?
I never understood how people have multiple pcv failures. Would seem like there is something underlying there
Nah, its the tunes. That's my point.Its literally the design and theres multiple possible failure points
