Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Regional Forums > CANADA
Old 02-27-2016, 11:56 AM   #1
animatrix
Oval Champion
animatrix's Avatar
Drives: 99 Golf GL, 2012 GTI DSG
Loose guard - body shop recommend?
The lower exterior guard below the door(not sure what you call it) is kind of loose from the circle highlighted. This pic is just reference. It's not obvious but it is not fully attached upon close inspection. Does anyone know where is best to get this fixed?
animatrix is offline   Reply With Quote
Old 02-27-2016, 06:38 PM   #2
nik
nik's Avatar
Drives: '12 CSG 6spd GTI 4DR
Mine has started to separate too. It's actually attached by four or so screws underneath. Once those are undone you can slide it (back I believe) as its on a key slot. Then pull off. Maybe check if the key way screws have come lose. If not you can probably tweak it a little by holding it against the rocker while tightening the screws below the car.
Sent from the crapper using Fapatalk
2012 CSG GTI 6 spd - /// Dynaudio / Sunroof/ BBS RS861's/ neutered soundaktor/ custom mount bright a** LED trunk light/ Door warning lights/ USP Delrin shifter bushings/ S3 SS/ LED Tails
Need VAG-COM in the GTA? Shoot me a PM!
nik is offline   Reply With Quote
Old 02-28-2016, 01:06 AM   #3
animatrix
Oval Champion
animatrix's Avatar
oic...I thought it was actually glued on, but I will have a closer look underneath. Thanks.
