Sniper260687
2011 GTI with 93K miles
So i got the p2181 coolant CEL code.
I did some research before posting and tried everything suggested even this.
* Check Engine Coolant Temperature Sender (G62)
* Check Coolant Thermostat
* Check Engine Cooling System
o Put the key on, fan speed on 1, and push the a/c switch. Are both fans kicking on? If not, you found the problem.
o Put the key on and fan speed on 1. Does heat come out readily from the vents?
+ No. Probably the water pump is gone.
+ Yes. Probably the thermostat is gone.
Both fans kicked in when the AC is on
Heat comes out normal and hot.
Coolant is full
Temps are normal.
Anything else?
Car is running just fine.
Coolant is full
Temps are normal.
Anything else?
