***HELP NEEDED*** 2011 GTI Various Warnings and Codes Popping After Dealership Repair
Stamkos91
So I have been having a large number of issues with my car. It's been in and out of shops and the dealership with more and more issues that keep coming up. I just had a timing chain stretch that caused timing to be retarded and was just repaired. When I got the car back from the dealership, the car immediately had more problems. A "oil pressure warning max 4000 rpm" error came up and I brought the car straight back to the dealership. The next day they told me they couldn't find anything. The car continued to have this issue, brought it back to them and still told me there was nothing wrong. Oil level seemed abnormally high so I took some oil out to where there was the correct amount in the car and it didnt fix anything. Now I'm getting more warnings which include an "ESP/ABS Error" and an "Airbag Error." I had both the battery and alternator checked but both seemed to be completely fine. I scanned the car with my OBD11 and found the following 12 to 15 fault codes. If someone could help me figure out what's wrong with the car and help me figure out how I would go about fixing it, I would be very thankful.
OBDeleven data log
Date: 2018-09-21 19:34
VIN: WVWFV7AJ1BW193495
Car: Volkswagen Golf
Year: 2011
Body type: 3-dr hatchback
Engine: CCTA 147 kW (200 HP) 2.0 l
Mileage: 85950 KM
01 Engine
System description: 2.0l R4/4V TFSI
Software number: 1K0907115AP
Software version: 0040
Hardware number: 1K0907115AA
Long coding: 0403010A1C070160
Trouble codes:
U1017 - ABS brake control module Read out DTC cannot be checked currently
Intermittent
Priority: 0
Frequency counter: 3
Driving cycle: 255
Mileage: 85940 km
P2261 - Turbo Boost Pressure Not Detected Mechanical
Intermittent
Priority: 0
Frequency counter: 2
Driving cycle: 255
Mileage: 85951 km
Intermittent
Priority: 0
Frequency counter: 1
Driving cycle: 255
Mileage: 85951 km
02 Transmission
System description: GSG DSG AG6 511
Software number: 02E300057C
Software version: 2724
Hardware number: 02E927770AL
Hardware version: F10
Serial number: 00001012030401
Coding: 0000020
Trouble codes:
P1847 - Read DTC memory of ABS CM
Intermittent
03 Brakes
System description: ESP MK60EC1
Software number: 1K0907379BG
Software version: 0106
Hardware number: 1K0907379BG
Hardware version: H31
Long coding: 114B600C492B00FD880F06ED921E0041B70800
Trouble codes:
00287 - Right rear ABS wheel speed sensor mechanical malfunction
Intermittent
00287 - Right rear ABS wheel speed sensor Electrical malfunction in circuit
Intermittent
01325 - Tire Pressure Monitoring Control Module No signal/communication
static
Priority: 2
Driving cycle: 83
Mileage: 85940 km
04 Steering Angle Sender
08 Air Conditioning
System description: AC Manuell
Software number: 7N0907426AC
Software version: 0303
Hardware number: 7N0907426AC
Hardware version: H18
ODX name: EV_ACManueBHBVW36X
ODX version: A01010
Long coding: 0000001002
Trouble codes:
No trouble codes found
09 Central Electrics
System description: BCM PQ35 M
Software number: 1K0937086L
Software version: 0615
Hardware number: 1K0937086L
Hardware version: 104
Long coding: 6D180A3A90272A04008800817000054442692086530D8D6064 8020200040
15 Airbag
System description: AirbagVW10G
Software number: 5K0959655B
Software version: 0706
Hardware number: 5K0959655B
Hardware version: 021
Serial number: 003C4R01GF80
ODX name: EV_AirbaVW10SMEVW360
ODX version: A01012
Long coding: 00003031
Subsystems:
System description: BF-Gewichtss.
Software number: 5K0959339
Software version: 0002
Hardware version: 007
Serial number: ---0000R--00059SEE00
System description: S.Sens.Fahr.V
Software number: 5K0959354
Software version: ----
Hardware version: H01
Serial number: 3572MSME230E525AZZZY
System description: S.Sens.Beif.V
Serial number: 3582MSME5975505AZZZ/
System description: S.Sens.Fahr.H
Software number:
Hardware version: ---
Serial number: 3512QSME1E497C16ZZZ2
System description: S.Sens.Beif.H
Software number:
Serial number: 3522QSME3E0F7B4DZZZG
System description: F.Sens.Fahr
Software number:
Serial number: 35527SME01433725ZZZ1
System description: F.Sens.Beif
Software number:
Serial number: 35627SME10742825ZZZ6
Trouble codes:
B10B300 - Function restriction of seat occupied recognition due to implausible message
Intermittent
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 5K0953507AJ
Software version: 0080
Hardware number: 5K0953549B
Serial number: 90440JL70017D
ODX name: EV_SMLSNGKUDS
ODX version: A05001
Long coding: 589A140000
Subsystems:
System description: E221__MFL-TAS
Software number: 5K0959542
Software version: 0010
Hardware version: H06
Serial number: 0074797
Long coding: 010000
Trouble codes:
17 Dash Board
System description: KOMBI
Software number: 5K6920971C
Software version: 0420
Hardware number: 5K6920971C
Hardware version: H20
Serial number: 00000000000000
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A04089
Long coding: 270F00
Trouble codes:
19 Gateway
System description: J533 Gateway
Software number: 7N0907530C
Software version: 0614
Hardware number: 1K0907951
Hardware version: H37
Serial number: 030111F2001471
Long coding: 350000
Trouble codes:
03272 - External audio source connection No signal/communication
static
1C Vehicle Position Detection
System description: Kompass 001
Software number: 5N0919879
Software version: 0001
Hardware number: 5N0919879
Serial number: 1225223RBGSA06
Coding: 0000002
Trouble codes:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03008
Long coding: 000000
Trouble codes:
2E Media Player Position 3
System description: SG EXT.PLAYER
Software number: 5N0035342D
Software version: 0150
Hardware number: 5N0035342D
Hardware version: H13
Serial number: 7669191911
Long coding: 010000
42 Door Electronics Driver Side
System description: Tuer-SG 009
Software number: 5K0959701B
Software version: 2117
Hardware number: 5K0959701B
Coding: 0001077
Trouble codes:
00109 - Mirror turn signal bulb, driver side Electrical malfunction in circuit
static
44 Steering Assistance
System description: EPS_ZFLS Kl. 74
Software number: 1K0909144M
Software version: 3201
Trouble codes:
01316 - Brake control module Please read DTC
Intermittent
46 Central Module Comfort System
52 Door Electronics Passenger Side
Software number: 5K0959702B
Hardware number: 5K0959702B
Coding: 0001076
Trouble codes:
00110 - Mirror turn signal bulb, frt. pass. side Electrical malfunction in circuit
Intermittent
56 Radio
System description: Radio
Software number: 6RD035187B
Software version: 5314
Hardware number: 6RD035187B
Hardware version: 534
Serial number: VWZZZ4H6230809
Long coding: 00000000000000
Trouble codes:
01042 - Control module not coded
static
02873 - Rearview camera system control module No signal/communication
Intermittent
77 Telephone
System description: TELEFON
Software number: 5K0035730
Software version: 1020
Hardware number: 5K0035730
Hardware version: H09
Serial number: 00007669065722
ODX name: UHVNA
ODX version: A01009
Long coding: 0A00000000010100
Trouble codes:
B104F13 - Left audio channel for speech/telephone Open circuit
static
B104E13 - Right audio channel for speech/telephone Open circuit
static
alpha3
check your ABS sensors, you have some bad one(s).
Stamkos91
So I was just driving the car and everything was the same. As I'm driving, the esp/abs error goes away, but the airbag light was still on. Its stays like this for about 5 minutes and then the car just dies and the battery light comes on. Rolled into a gas station, turn the key off and turned then back on and it starts up fine with no error warnings. Drove home, scanned the car and all the codes were still there. I emailed myself the datalog and cleared the codes. After that I rescanned and none of the codes or errors come up like they did right after clearing them before. I turned the car on and off, and rescanned it a couple more times and there was still nothing there. I have no idea whats going on and really need someones help to try to figure out what is going on. This is the second time the car had just died while I was driving, but the codes were still there after the fact. The battery voltage is fine when the car is running and when its not, and the alternator was checked before and was fine. Please help.
sterkrazzy
Could be your abs sensor going out, or it could just be dirty. My car was doing exactly as you described for a couple weeks after every start up and now it hasn't happened in a while.
The oil pressure thing is a funny one. There's been a lot of people that see that error once or twice and never again, nothing was wrong, and no idea why it triggered. I've seen it before in my car like 4 years ago and not since.
Welcome to the world of vw ownership lol
alpha3
If you get a ''christmas tree'' of warning lights again, airbag, steering, TPMS, abs, it's one or more of your ABS sensors. Your log above shows it's your right rear sensor.
