Old 12-08-2018, 04:51 PM   #1
GTiMKVI
Drives: 2011 VW GTi DSG 4DR AUTOBAHN
WARNING OIL PRESSURE CHECK OWNERS MANUAL AND SHUT OFF ENGINE
Hi Everyone, this recently showed up while I was driving. It comes and goes, so I took it for an oil change and it was half a quart low. Picked up the car after the oil change and the OIL Pressure Warning showed up again. Any ideas what it could be?
Thanks
GTiMKVI is offline   Reply With Quote
Old 12-08-2018, 05:43 PM   #2
GeorgiaBII
GeorgiaBII's Avatar
Drives: 2011 APR Stage 2 DSG Autobahn
Bad oil pump, bad sensor, clogged pickup tube.
Best thing to do is NOT drive the car and have it checked out.
GeorgiaBII is online now   Reply With Quote
Old 12-08-2018, 09:05 PM   #3
BudgetPhoenix
FIA GT Newbie
Drives: 09 GLI
I got 10 on it being balance shaft failure
Old 12-10-2018, 03:10 PM   #4
GTiMKVI
Thanks guys. I guess I have to bring it in for diagnostic testing. I drove it today and there was no warning. Also checked the oil and it’s still on max level, so no leak.
Old 12-11-2018, 09:17 PM   #5
FocalPoint
Formula 3000 Champion
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
Originally Posted by GTiMKVI View Post
Thanks guys. I guess I have to bring it in for diagnostic testing. I drove it today and there was no warning. Also checked the oil and itís still on max level, so no leak.
Doesn't mean the pump isn't done.
FocalPoint is offline   Reply With Quote
Old 12-17-2018, 06:40 PM   #6
GTiMKVI
Just went to the dealer. Nothing came up in the scan, and the warning didn’t pop up again. It had not popped up in 5 days but I had an appointment so I brought it in. The dealer said it’s probably a switch issue. They won’t charge me for diagnostics if I bring it in again for the same issue, so that’s good. I will keep you guys posted.
Old 12-17-2018, 08:57 PM   #7
FocalPoint
FocalPoint's Avatar
Last time this happened to me, a bearing slipped and I ended up with a new long block. Hope you've got an extended warranty.
Old 12-21-2018, 09:33 PM   #8
GTiMKVI
Warranty is done. Have had the car for almost 8 years. Only emissions warranty now.
It’s probably the sensor.
Old 12-24-2018, 10:16 AM   #9
demon342
Drives: 2011 mk6 GTI 2.0T
Idk about the senor, its an easy replacement so I would do it but I also had bearing slippage and this was that message was the first sign
11' MT6 GTI 4 door sunroof. 150K miles on the clock, mainly stock....for now
demon342 is offline   Reply With Quote
