Mid install of K04 - need some help
lilfleck
Two things,
One, I'm still fighting the 6mm Allen holding the heat shield on top of the exhaust runners.
Two, the downpipe studs on the k04 (used) are a little dirty. I'm going to try to retap the threads to clean them and then try the new downpipe nuts.
One of the studs came out with the nut. Can I reuse the stud? Could I reuse a stud from the ihi? Do I need a special tool?
Sent from my Galaxy Nexus using Tapatalk 4
Cryptic19111
don't retap them to clean, hit them with a wire brush to clean the gunk off. As for the other stuff, I'm not sure
Kal-GTI
I ripped the f'n heat shield out by hand on my car because I stripped that third screw out. Not reccomending that but it's an option. Try going in on the right side of the engine where the intake piping was.
lilfleck
Finally got it... Took a special Allen with a ball on the end. Now I'm stuck on the turbo bracket Allen.. Same issue. It's freaking stubborn. Will continue in the morning.
I'm just really scared of stripping bolts.
On a side note, anyone know how to remove this vacuum line?? I was squeezing and pulling like no other.
Cryptic19111
get a maxjax low height 2 post lift in there!
KKrayZee
get some loctite stud lock pur the stud back in leave overnight then try taking the nut off again should work,
if you have the exact same size die, should work too clean threads, but a wire brush is safer
greasyginzo
You can chase the threads for the studs with a tap but its imperative you use the correct size tap and run it in true. When chasing threads you run it straight in and out not 1 turn back a half like you are cutting new threads
Kal-GTI
Comes apart like the Pcv connector on the intake piping. If I'm looking at the right vacuum line.
lilfleck
Well it's morning now. I will try to loctite it first thing. What is the best way to tighten the stud to the turbo?
Ok. Will try a wire brush first.
That was just as difficult...
2013R
sucks. almost guaranteed to crack if its old and brittle. like mine did. dont use any sharp tools like screwdrivers, just keep trying with your hands
