Many people run the stage 2 daily with a k04.
The most daily drivable, longest lasting is a organic.
You sure about that?
Ah, okay. Thank you. Seems like the engagement is super oem-like on the stage 2 endurance. But I dont understand, its not good for street use?
I'm sort of confused about the two versions of Stage 2 Endurance clutches shown on the Ringer Racing website:
http://www.ringer-racing.com/product...&categoryId=85
Stage 2 - HD-TZ (Endurance)
•Contains a modified high performance HD pressure plate with a heavy duty Kevlar lined disc. The metal backed Kevlar linings provide a smooth engagement and have the torque capacity to handle high horse power, high revving engines.
Stage 2 - HD-OFE (Endurance)
•Contains a modified high performance pressure plate with a A Feramic full face lining on the flywheel side and a Medium Metal content Organic lining on the pressure plate side. This combination runs cooler and significantly extends the clutch life.
•HD-TZ = 425 ft lbs
•HD-OFE = 450 ft lbs
So if the HD-TZ with its Kevlar lined disc isn't ideal for daily stop-and-go driving, is the HD-OFE more suitable for such uses? My daily commute is ~6.5miles of stop and go city driving and I'd like something that will eventually be able to hold up to K04 power. I doubt I will ever Auto X, but once I get a clutch installed it will probably see 1 or 2 trips to the drag strip (street tires only) each year.
The TZ can be smooth but not nearly as smooth as the KV which is the FX200. Problem with Kevlar is that it can not handle being over heated which can happen in really long stop/go drives. It also seems to wear out quickly on really heavy cars which is why CM started offering the Fibertuff that is on their new FX350.
The OFE is the disk they use for the drop in disk. It is their normal stage 2 endurance but I also offer the TZ stage 2 which is what they used to offer before changing their line-up back in 2010.
Their old line up was.
Stage 1 Rally (HD-O)
Stage 2 HD-TZ
Stage 3 HD-OFE
Stage 4 SS-OFE
Stage 5 SS-FE
So would you say the OFE is smooth and suitable for daily stop & go driving? The revised SB kits seem to be a bit quieter than the CM kits and, at $1,050, the Stage 2 Endurance seems like a good deal.
Anyone else's head spinning yet? Southbend has the heavier flywheel right by 2lbs? Thinking about going w/ the setup w/ a slightly heavier fw for less noise.
Kind of skeptical going for the stage 2 daily if I ever went K04 because of the 400tq limit. APR lists the K04 w/ turboback @ 380tq. Add in an intake, IC, and some other supporting mods and I'm sure your right at or around the 400tq limit. I'm hoping/assuming that South Bend is conservative with these numbers...
Dangit this aint easy.
Looks like a quality piece ^^
Anyone (Mike or Dave) know if the SBC kits will fit a stock dmfw unmodified?
butchered by autocorrect
**Added
Just talked to SB and I can offer them at the prices I first posted up which is the price that SB has on their site at this time, once SB changes their prices on their web site then my prices have to go up too.
So these prices are what I will be offering them at for now.
Stage 2 Daily = $950
Stage 2 Endurance = $1050
Stage 3 Daily = $1350
Stage 3 Endurance = $1400
Is this for the old disk setup then? Meaning not the updated Exedy disk people are talking about.
Yes, my head is spinning, somebody said that......somewhere......sometime.
