PR_dub
Got a code last night and haven't had much luck searching online, maybe you guys have a clue what it might be.
P0010 bank 1 camshaft A (intake)
Camshaft actuator malfunction
Was running an M4 and had a couple of rolls from 60, when I pulled off on my exit, looked down and saw check engine light come on. On one of the runs I shifted at 7k 4th to 5th.
The car seems OK with no sounds nor vibrations. I cleared codes but still pop back after engine is started again.
Oil level is ok, fresh change a week ago, might it be a tensioner problem? Skipped 1 tooth on the chain? Want to see if it's something I can sort out or it has to go to the shop to further diagnose.
Car is APR K04 FBO
Any help is appreciated. Thanks
Car is APR K04 FBO
