Weird Noise Knock from Tranny
#madrussian
Hey all,
Was driving last night and noticed a weird situation with the car.
At above 3.5K rpm if I drop the throttle then get back on it there is a very noticeable knock like a catch up of the engine to the transmission or something. Feels quite unsettling, almost like a clutch drop.
Really only happens in 3rd and above gears, in 1st and second its like the engine and tranny are glued, the flow of rpm up and down is very consistent without breaks.
Has anyone has something similar occur? Is it time for a new clutch? Or something worse?
Any info would be appreciated.
Thanks.
#madrussian
The Fixer
Clutch slip? Are you tuned?
visceralsoup
My car has this issue too. Its like something in the drive line is shifting. I have upgrade mounts though so I dont think it is the engine or tranny. My thoughts are maybe the rear differential
The Fixer
I believe it's the differential wearing out. Good excuse for LSD upgrade.
iGTI1
Most likely the rear... check for leaks not sure how many miles you got but thats not an area you want to neglect.
visceralsoup
Ive inspected it and there are no leaks. I think I will do a fluid change soon. I know a guy selling a warrantied diff so I might get it just in case
bebersol
is that the rubber bushing where the drive shaft connects to the transmission and rear diff?
I think it's called a Rear Harmonic Balancer.
bebersol
ECS has a replacement for about $150, it's exactly the same as the $460 OEM part because FEBI manufactures the part for VW
