Old 06-21-2016, 12:24 PM   #5209
kern417
Drives: '09 Jetta
i wish i had news. i'm being lazy with my teardown. but hopefully once it's back up i'll have the 5th injector everyone and their mother recommended so i can get back in the game and dyno.
do a burnout.
Old 06-21-2016, 12:25 PM   #5210
apa11393
Did you ever figure out that lambda issue?
Old 06-21-2016, 12:28 PM   #5211
james9120
james9120's Avatar
Drives: 13 R
Dereks too busy on the beach
james9120 is offline   Reply With Quote
Old 06-21-2016, 12:52 PM   #5212
jettaglis
jettaglis's Avatar
Drives: '88 gli,'10 cc,'11 tiguan,'12 gti
I'll be doing race car things this weekend with Derek. Street car take over is here in Charlotte. I'll be doing the fwd roll class and drag racing possibly.
Uni stage 3....gtx3071
Old 06-21-2016, 01:01 PM   #5213
james9120
james9120's Avatar
Drives: 13 R
Nice! Can't wait for to see those videos
Old 06-21-2016, 01:17 PM   #5214
erball
erball's Avatar
Drives: Rolling burnouts
Fuck it i'll update.
On revision 2 of my tune. Running 23psi with meth currently. Trying to figure out my issues still, and i'm at a loss. Currently car is spooling terribly, and i'm not sure why. Seeing 23psi at around 5100rpms. Setup is AFI tubular vband manifold, tial .86 vband turbin housing, tial mvs, gtx3071r.
Have boost leak tested it, and it holds pressure on the cold side. My setup is vbanded and while i'm not seeing or feeling leaks, i'm not exactly sure how to tell proof positive. Outside of that it's definitely getting faster.
New tune has NLS and it's made a world of difference in keeping pressure up between 3-4-5. In my defense i have a 5 month old, just moved, and do all the work myself, so i don't care if the car takes 3 more years to finish.
Big Turbo Build Thread.
erball is offline   Reply With Quote
Old 06-21-2016, 02:28 PM   #5215
jettaglis
jettaglis's Avatar
Derek I'm sure will have his go pro, I'll snapchat what I can. (too bad you deleted your snapchat)
I'm sorry your still having troubles, my daughter just turned 3 and 3 years will fly by before you know it!
Old 06-21-2016, 02:37 PM   #5216
kern417
Drives: '09 Jetta
no. fuel trims are still turned off. my only assumption is they set it in open loop for whatever reason and either my injectors are different than everyone elses or they just tuned it wrong. i tried having a convo directly with etuners but struggling to get responses quickly. kind of deja vu. i have my 02 gauge installed and it still shows extrememly rich at idle (10.5-11). in boost it didn't show lean (~11.5). regardless, it's running richer than necessary and it won't let me add more boost if it keeps thinking it's running lean.
after tearing this apart i'm thinking about just doing piston rings at the same time since i was planning on doing it this winter. compression and leak down never came back bad but excessive blowby could cause a lot of problems anyway.
i still think it's the turbine housing. but hey, i have nls too ...
do a burnout.
Old 06-21-2016, 04:34 PM   #5217
jettaglx91
Drives: 450whp TSI GTI, 420whp R, stock CC
I put my driveshaft in the other day. Or prop shaft as the germans would call it.
jettaglx91 is offline   Reply With Quote
Old 06-21-2016, 08:12 PM   #5218
U-20T
Drives: BT GTI4Motion
Just over here glued to the seat
Old 06-21-2016, 08:58 PM   #5219
RGTI13
Drives: 2013 D.E. DSG GTI
Why tf is this thread so dead? Derek stop marathon eating cheetos and post some pics of your new racecar or something
Lol
Old 06-21-2016, 09:02 PM   #5220
RGTI13
car is spooling terribly, tial .86 vband turbin housing
Also, double check your WG/DV. Make sure it's not cracking early. That will cause late spool.
Old 06-21-2016, 09:03 PM   #5221
RGTI13
I'll update.
Stress free with a stock GTI. Everything is running well.
Old 06-21-2016, 10:24 PM   #5222
james9120
james9120's Avatar
Drives: 13 R
Big Turbo Discussion Thread #2
Semi stress free.
Driving car, cruise control stopped working. Restarted car, cruise control is working again.
Also, I was thinking of going all custom wide body. Thoughts? Is it more involved than just adding the appropriate wheel spacers?
addicted to torture, blow up ur volkswagen, breaking your trans 101, failwheeldrive anonymous, fireball lives!, james'partout
